Go Back   R/C Tech Forums > General Forums > Monster Trucks
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 10-27-2009, 01:47 AM   #1
Angry Problem with my revo 3.3
I have the Revo 3.3 and every time i get air over a jump the engine cuts out weather it be in the air or even when it lands! Any help would be greatly appreciated! Thanxs!!
dman6479 is offline   Reply With Quote
Old 10-27-2009, 11:40 AM   #2
Send a message via AIM to boomgagem
Are you off the throttle when the engine cuts out?
boomgagem is offline   Reply With Quote
Old 10-27-2009, 03:54 PM   #3
bigblockt-maxx's Avatar
Send a message via AIM to bigblockt-maxx
Set your idle higher
WICKEDWAYZ RACING
<> LOSI 8ight t 2.0 <> RJ Speed pro stock <> Sportwerks E Turmoil <> HPI Savage <> Ntc3 <>
2010 sponsors - Nitro rcx Racing
bigblockt-maxx is offline   Reply With Quote
Old 10-29-2009, 10:05 AM   #4
OG RC 10T's Avatar
Trader Rating: 22 (100%+)
I was going to mention the idle setting as well. Also check to make sure the carburator is secure. If it is loose it will cause it to cut out as well.
Original RC 10T. Bl eRevo, Tekin RX8.
OG RC 10T is offline   Reply With Quote
Old 11-02-2009, 01:53 AM   #5
The problem is that the idle setting is way to high because when i let the throttle off the Revo takes of at a bit faster than waking pace is this normal???
Old 11-02-2009, 02:25 AM   #6
Yes i am on the throttle when it cuts out Thanxs Damian!!!
Old 11-02-2009, 05:26 AM   #7
Well, your idle gap should be about 1mm or so. Your LSN may be too rich, or your clutch shoes might be worn or the spring might be broke.
It's probably in the tune, richen up the LSN and check the IDLE gap
Old 11-02-2009, 05:41 AM   #8
xrayeddy's Avatar
Trader Rating: 68 (100%+)
Faulty fuel tank, broken fuel line, tuning issue, carb issue, clutch issue, ...............................
Could be a few things. I'd suggest cleaning the truck thoroughly, and inspecting everthing. Pull the engine out, check the clutch bearings, shims, shoes, and the carb. The only way you'll figure out a problem now or in the future is to work on it.
Team Terribles
xrayeddy is offline   Reply With Quote
Old 11-02-2009, 06:28 AM   #9
One way bearing, don't forget that.
tmaxxdaddy1 is offline   Reply With Quote
HTML code is On
Forum Jump
revo 3.3 header problems cupton79 Monster Trucks 7 04-26-2009 05:32 PM
Issue with my Revo TRX 3.3 Engine TADitto Nitro Off-Road 11 01-02-2009 06:54 PM
Steering problem with 3.3. Revo matts6887 Monster Trucks 24 04-01-2008 04:02 PM
revo 3.3 for a beginner??? grevo_33 Monster Trucks 99 07-30-2006 02:17 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
