I currently have a 2000 bl motor in my eRevo, geared 18 / 68.
I need to go up on the pinion and wanted to go 20 / 68.
The question is will a 20t fit or will I have to change the spur as well. If I have to change the spur can you suggest what pinion would go with the changed spur.
I just dont know the formula for keeping the ratio the same with the changed gears.
Thanks.
Original RC 10T. Bl eRevo, Tekin RX8.
I see, well if i remember correctly, mine came out of the box with 18/65 and a optional 54t spur. running 18/54 was a great improvement. Or since you already have a 20t pinion, try 20/56
