Go Back   R/C Tech Forums > General Forums > Monster Trucks
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 10-13-2009, 12:22 PM   #1
Default savage flux, 4s in one tray?
can a 4s pack fit in one battery compartment on the savage flux?
Needler56 is offline   Reply With Quote
Old 10-13-2009, 12:50 PM   #2
vstrok's Avatar
Don't think so.
Savage Flux - Sick!!!
Slash - 5700 Mamba System
1/16 E-Revo VXL Fun Fun
RC10 - Vintage Restoration Project (Any Suggestions??)
vstrok is offline   Reply With Quote
Old 10-13-2009, 01:01 PM   #3
Trader Rating: 15 (100%+)
Def not, at least, no 4S I've ever seen. They're too tick to fit in the batt boxes.
I can barely get my 3S to fit.
Duster_360 is offline   Reply With Quote
Old 10-13-2009, 01:06 PM   #4
cyclone x's Avatar
why would u do that anyways
Chase Chandler
Sponsors:
ABC Hobby, The Track,CFX Paintworks,Stevo Racing
cyclone x is offline   Reply With Quote
Old 10-24-2009, 04:05 PM   #5
RCZILLA's Avatar
Maybe because a single 4s is cheaper than 2 x 2s lipos
RCZILLA is offline   Reply With Quote
Old 10-24-2009, 05:01 PM   #6
How about the balance then? Not practical, even if it would fit.
Old 10-24-2009, 09:13 PM   #7
OG RC 10T's Avatar
Trader Rating: 22 (100%+)
The compartments were designed for 2 - 2cells, one on each side. They are not tall enough for one 4 cell.
If your good soldering, buy a 4 cell and take it apart. Put 2 cells in each side, they will fit, and you would have saved some money.
Original RC 10T. Bl eRevo, Tekin RX8.
OG RC 10T is offline   Reply With Quote
Old 10-25-2009, 07:48 AM   #8
to deal with one battery rather than two.
thanks for the info guys!
Old 10-25-2009, 09:38 AM   #9
Originally Posted by OG RC 10T View Post
The compartments were designed for 2 - 2cells, one on each side.......
The batt boxes are designed for 2 3S lipos, Flux is designed to run 6S like the ERBE. I have "car" size 3S lipos and they are tight, have to reverse the boxes so the lids can open fully, but otherwise they really fit better than 2S lipos since they're snug in the boxes.
Old 10-25-2009, 10:22 AM   #10
Based on dimensions, these should fit:
http://www.hobbyking.com/hobbycity/s...idProduct=9511
They do in the E-Revo.
V0RT3X is online now   Reply With Quote
Old 10-25-2009, 01:20 PM   #11
Still, I question the balance. Thats 437grams on one side, 15.5oz thats not balanced, its going to be noticeable in the air...... prob notoceable in how it turns as well.
You know you can buy a series connector and charge 2 2S lipos as a single 4S so you effectively charge only 'one' lipo? That way you could use a pr of higher capacity like 6000mah lipos and get 50% more capacity over the single 4000mah 4S. I'm pretty sure the SMCs 6000s fit. I run 2 2S 5000mah lipos.
Old 10-25-2009, 02:15 PM   #12
J_Man's Avatar
If it does fit, you can buy two and run in parallel to get 8000mAh of stupidly long run time...."If"
MUGEN SEIKI MBX6-T
MG66 6 Port .21/GO Rspec 3 Port .21
GO Pipes 0801/2072
Savage Flux PRC CF/EXT *Monster Evolved*
J_Man is offline   Reply With Quote
Old 10-25-2009, 04:24 PM   #13
But the OP wants to get by with a single lipo......
Old 10-26-2009, 09:10 AM   #14
OG RC 10T's Avatar
The 2 cells are tight, but you right why would they say you can run 6 total, but only have room for 4.
Typing with out thinking out side the box - thanks.
Old 10-26-2009, 03:10 PM   #15
Freezebyte's Avatar
Some 3S packs barely fit in there, so a 4S has no chance in hell of fitting, not unless you mod the crap outa the tray's, which they need anyway.
Freezebyte is offline   Reply With Quote
HTML code is On
Forum Jump
Hotbodies Ve8 joelwhite Electric Off-Road 1596 Today 02:00 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
