having trouble tunning my savage x 4.6 help needed
I have been having trouble keeping my savage x 4.6 tuned. I was driving my savage yesterday and it was running great I could barely keep the frount wheels on the ground. I cheacked the temp. it was running at 220 exatly. Then I made a few more passes and then with out warning it started running like crap. After that I could not get it to run right. It had a bad lag in the throtle from idle to wide open and also ran week. i have only ran 7-8 tanks the truck is new. Please help.
probably midtank lean look around for the mod for the savage
well this mite sound like a stupid question but i just started using fule filters on my nitro trucks and when it started acting up was the first time i ran it with a fule filter on it could that have any thing to do with it
Yes, fuel filters can be an air leak. Take it out, replace line with a single piece of fuel line and see if prob goes away. If it does, get a better fuel filter if you want to continue to use one. I use small zip ties on the fuel lines to help prevent leaks. Make sure filter is tight enough not to leak.
do you think fuel filters are really nessary for some one that just drives with friends on the grass
to every one that gave me advise on this matter thank you i have never had this happen to me before it the year i have been driving nitro trucks
