hey every one im having a few problems with my revo 3.3, first off im curious what kind of glow plug would be good for florida weather with temps between 70F and 95F degrees? also my revo is shifting way to late and cant figure out what kind of wrenching device i need to make it shift sooner? and what is a good temp to run the trx 3.3 engine at and what temp should i not go over?
thanks in advance.
daniel
The glow plug you need is a medium. I use model technics medium, but they are a UK brand.
you need a 2.5mm hex driver (allen key) to change the shift point. take a look at the manual, it tells you how to do it.
I can't tell you what temp to run at, as it varies, but don't go over 290F.
yea i dont have the manual, i got the revo in a damn good trade, as for the temp i have heard it can run between 220 and 280 but i wasnt sure and wanted to get an idea from others who are more knowledgable about the engine then me
yes thats the degrees you want the motor. Do you have a temp gun?
BIG BLOCK TRAXXAS SLAYER FOR SALE
yes i do, here are some pics of my beast i have a revo platinum body and wing for it, i traded a first gen team associated rc10gt for it straight up and it has a new engine let me know what u think
Look under the "Revo 3.3 (#5309) for manual - clicking manual will bring it up - its a pdf and you can save it so you'll have it. I have a folder on my PC for each of my RCs that has the manual, parts lists and all the exploded views for reference. You'll be surprised how useful they can be.
Looks like a good deal - like the custom fuel shut off...
In mine the glow plug I use an O.S LC 3 or an LC 8 they are a little bit longer and fit down inside the combustion chamber a little further in my opion it bumps up the compression a bit more. The LC 8 is a med hot plug that might be best where your at.
