SSlipper clutch
SSlipper clutch
How many turns out should the slipper clutch bolt be turned out on a Tmaxx 2.5? Thanks guys!
Ok, I figured that out, now a new problem, I managed to take the screw out of my 2-speed ( the adjuster screw ) now I dont know how far to put it back in!
Neat, cheap hopup - add 6 more pegs to the slipper and run 12 instead of 6, makes slipper better. Tighten til spring binds and loosen no more than 1/4T. I keep mine at 1/8T - looser slips too much.
I 'd screw the adjuster in until you feel the spring unde it start to resist. Test it and see where you are. From there, its T&E, 1/8T at a time. CCW to lower shift point and CW to raise it.
