Go Back   R/C Tech Forums > General Forums > Monster Trucks
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 11-09-2008, 06:54 PM   #1
Default Saage diff with hellfire gears? Is this possible
Hi, i was wondering if anyone knew if i would be able to use a hellfire ring gear and pinion gear in a savage rear end (or a combination of savage ring and hell fire pinion or vise versa), i saw another post that put some savage components into a hellfire rear end and all that was required was some interchanging of bearings. I have put a 2 stroke sthil fs 35 trimmer motor into my savage but i want a lower gear ratio in the rear end, the motors clutch bell is coupled directly to the pinion gear so the only way to get lower is with different pinion or bevel gears(if possibe). The ratio in the hellfire (42/10) would be perfect for it as opposed to the savages 43/13 ratio, about 25% difference.
racerjamie is offline   Reply With Quote
Old 11-10-2008, 04:43 PM   #2
helibrian's Avatar
Anything's possible! We tried this for a while, thinking they might last longer than the stock savage gears but it didn't work out that way.
There's lots of shimming and general screwing around you've gotta do. And you do have to use the 8x16x5 bearings (they last longer anyway). The pinion is gonna have to be shimmed further into the bulkhead. It's real important to get this just right. Also it doesn't like to be shimmed up by the teeth because of the stop-gap, so you can test fit everything with a spacer/sleeve, which you'll have to make (sorry can't remember the exact size), get it all perfect and green locktite the spacer on or you can stick a couple shims under the inner pinion bearing, (I don't like that much but....eh...for your truck it's ok. hehe).
You can't use the pin that holds the input drivecup because the hellfire pinion has a flat spot instead of a hole. The pinion won't be sticking out far enough to just drill a hole in it. It doesn't stick out much at all in fact. So you've gotta use a set screw or cut the pin part off the original fastener. I can't remember if we used the stock savage drive cup or something else.
I know I said anything's possible but, nope you can't mix-n-match because the hellfire gears are semi-helical cut and the savages gears are straight cut.
If it were me, I'd probably do my best to figure out some kind of gear reduction at the clutch and put cen diffs in it which will produce a higher ratio (2.89:1), but are tough as nails.
Ok, I wanna see some pix of this beast!!!
helibrian is offline   Reply With Quote
Old 11-10-2008, 05:39 PM   #3
Here it is, its still a work in progress and will get another total re design soon, so it will change again to incorporate a gear reduction:
Old 11-11-2008, 04:34 AM   #4
helibrian's Avatar
Now THAT"S what I call a FREAKIN MONSTER TRUCK!!!
Old 11-11-2008, 05:05 PM   #5
Thanks!
HTML code is On
Forum Jump
Mini LST VXL Motor Mod makakoa808 Micro and Mini Scales 55 02-23-2009 06:50 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
