Need help with savage 2 speed.
Hey whatsup..? I have a savage with the hpi s.25 still in it, a hb pipe and 52/15 gearing. The problem is, my truck is either always in 2nd gear unless i stop and slowly give it throttle then when it shifts, punch it, kick up dust and pull away. since all i drive on is dirt, that might be the problem. i got my trans set: the second set screw 5 turns out and i'm not sure about the first set screw.i tighten my slipper and nothing happend as i thought that might be the problem because i like a loose slipper because i want to conserve my spur.(would that help, dont really know, just going off what i think)
Anyone have this problem? Any suggestions?
help's appreciated
help's appreciated
its gotta be something in the setting. you could also pull it apart and look for the obvious(i.e. stripped gears, metal shavings...)
you've probably already seen this.
+ YouTube Video | |
