!~R/C Fuel Tank Adapter~! >
Old 12-10-2007, 01:19 AM
xsxracing's Avatar
Trader Rating: 33 (100%+)
Thumbs up !~R/C Fuel Tank Adapter~!
Hello,
I have an idea that i would like to share with you.
These will change how you refuel your nitro fuel tank.
Now not saying it will go big or anything but i think it could help a lot of poeple and make your refuel time a lot quicker.
These is going to be hard to explain over the comp but i will try my best.
Ok,On all nitro R/c's you have a Fuel tank.The lid on the fuel tank were you push open and pour fuel in.So most poeple put Zippie ties on the lid so wene they come in for a pit stop you just pull on it,It open's the fuel lid and you pour your gas in and goo!
Now i have a different idea for the fuel tank.
Ofcourse you will still have the tank but you take the lid of the tank and you put on a peice that goes over the circle fuel lid and it stay's.I am calling it a condom.
But you take of the regular lid and put on the peice over the circle on tank and it will stay on here.
So you got the peice on there now i dont know what to make it out of,Maybe get a little square of fuel tubing,Cut out and put on it like a Condom.
So say you have the fuel tubing over the circle and it is on there good and takes some force to get off.Now you gotta make small cut's around around it like a circle,So thene you can now put your finger in there and take back out.
Ok so say you got that and wene you come in throw the pit area all you gotta do is stick your fuel bottle-fuel gun throw the little body hole and squeeze the fuel in and go.Now that save's you a lot of time and you dont have to take more time and pull on the zip tie to open the lid all you do if pour the gas in and goo!
Now i know most of you are probly thinking that will never work because even though you can put the fuel in there without opening anything wene you take jump's the fuel will jump out of the whole a little bit.Yes i have though of that and i have found a way,Wene your making the little cut's on the tubing just make sure your blade is really small and it will not let much fuel get out if any becuase if your blade is too big wene you jump or land over on its back fuel will get everywere.
Now let's talk about the the peice that will do everything,It can be fuel tubing which i think would be the best or there might be something better but i can not think of anything right now.
Here is a little link to an adapter that the Paintballer's use(Speedballers) put on there electronic loader so they dont have to open the lid and pour p-ball's in they just pour paintball's in and that's it.
Link Below
http://www.actionvillage.com/is-bin/...sAAAEPiwujEgyB
Now a lot of poeple maybe thinking right now that is stupid and it wouldnt ever work but just take time and think about it.Save time,Faster pit stop's etc....
Now i though of these a while ago and still thinking about it but tryed telling some friend's but they were geting confused.
So what do you guy's think???
So little review,You take off lid on tank,put over a quare of fuel tubing,cut out to make circle around lid tank,Use small knife or hobby knife and but line's around the whole in the tank,Pour fuel in and Gooo!
Well tell me what you think.
Long read hu lol sorry.
Thnx,XsX/Dave
xsxracing is offline
Old 12-10-2007, 02:38 AM
Trader Rating: 29 (100%+)
I don't understand how you think small holes from a hobby knife are going to allow enough fuel to get into the tank. It seems to me like you'd be wasting more than you actually use just trying to fill the tank. If the holes are big enough to easily fill the tank, they'll be big enough to easily drain the tank as well. Don't forget your fuel tank is pressurized.
revo_race is offline
Old 12-11-2007, 06:30 AM
wog....supraman's Avatar
i agree with the guy above....iam confused!!??
wog....supraman is offline
Old 12-11-2007, 06:07 PM
It's actually a fairly good idea. Unfortunately, it will never work on an RC engine. Like Revo-race said, the tank is pressurized from the exhaust, which helps force fuel through the carb. Your idea has no seal, and the tank won't be able to build any pressure.
To the other guys, think of the lid of your tank having slits like * cut in the top of it. That's what he's talking about.
Jeckler is offline
HTML code is On
