Go Back   R/C Tech Forums > General Forums > Monster Trucks
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 11-04-2007, 03:34 PM   #16
i looked and i was wondering why shouldnt i get the .32 if it has more horsepower than why shouldnt i get it i know its heavier but in a stock savage (permitting the stock drivetrain can handle it) which would win .28rr, 28 spec1s, or .32
super jato dude is offline   Reply With Quote
Old 11-04-2007, 06:43 PM   #17
jatoman1992's Avatar
Trader Rating: 4 (75%+)
Send a message via Yahoo to jatoman1992
i think in the long run the .28 would out perform the .32 and the .28 RR would out run both, but not last as long as either. if you ask me anything from .21-.28 is the sweet spot for rc nitro engines.
If i were you i would go on youtube and look up both engines and see how they perform. get which one you like best.
Pre-mix:
Kawisaki KX125-bored out to a 134cc, VForce reed valves, FMF gold series pipe and shorty silencer, phathead racing cyl head w/ interchangeable domes, and wiseco flat to piston
Nitro:
Ofna Ultra LX Pro- Axial .28 1S w/ JP-2 Pipe, Hitec HS5645MG(steering) and Hitec HS625MG(Throttle/Brake)
Electric:
Losi Micro-T- stock
Coming soon: Associated FT B4- stock
Ofna LX Pro as a roller w/ extras- $150
Starter box(1/8 buggy) w/12V battery- $70
micro T- $50 OBO
Axial .28 1S- 6 gal. thru- $50 OBO
jatoman1992 is offline   Reply With Quote
Old 11-04-2007, 08:56 PM   #18
Trader Rating: 42 (96%+)
Send a message via Yahoo to loopedout
I havent had a problem one with my 28RR engines, mine seem to run around 230-260 after a 4min race and actually come off at 220ish after a long main. Ive found its not a low end torque motor, I have an 086 pipe on it with really stiff clutch springs and its a rocket
loopedout is offline   Reply With Quote
Old 11-05-2007, 04:06 AM   #19
ok ill try that looking up both engines
oh and does the stock savvy clutch setup go right onto an axial engine or what do you need to do
Old 11-05-2007, 08:56 AM   #20
RCH
Location: SW New York State, Soon to be Philippines, thank God!
The Axial engines are the same crankcase blocks and back plates as the HPI .28 4.6. So the OWB, One Way Bearing, pullstart and roto are the same. As are the heads interchangeble.
RCH is offline   Reply With Quote
Old 11-05-2007, 09:03 AM   #21
the 28rr is a little different on the head(might be interchangeable but has a different button) and you have to run a 32 backplate on it, the 28 spec1 back plate interferes with the piston
Old 11-05-2007, 02:23 PM   #22
they are mostly the same but axial is higher quality and more powerful:
http://www.nitrodynesystems.com/HPI%...%20compare.htm
Axial .28 spec 1S: 1.43 HP
HPI K 4.6: 1.26 HP
they are running all the same things(pipes, fuel, etc.) exept for the glow plug.
The axial also revs a little bit higher.
Pre-mix:
Nitro:
Electric:
Losi Micro-T- stock
micro T- $50 OBO
Old 11-05-2007, 03:04 PM   #23
wow i never knew they were so much alike is that good or bad cause i only got 4 galons so far in my 4.1 and its dead so that sucks. Average how much life does an axial get
Old 11-05-2007, 03:48 PM   #24
Originally Posted by jatoman1992 View Post
like i said, bigger is not always better. i have almost 4 gallons on my .28 1S and it is VERY hard to turn the flywheel still. axial makes great motors...thay just need to re-think the .28 RR. the average life span of a .28 1S is 8-9 gallons, great for under 140 dollars.
says right here, if you dont abuse it during break in.
Pre-mix:
Nitro:
Electric:
Losi Micro-T- stock
micro T- $50 OBO
Old 12-05-2007, 02:34 AM   #25
Dave_x8's Avatar
Send a message via MSN to Dave_x8
i wouldn't advise thrashing any motor during break in...unless ofcourse you have a spare, if thats the case.....hold it flat_
Dave_x8 is offline   Reply With Quote
Old 12-15-2007, 05:35 PM   #26
maxximizer's Avatar
Default axial 32?
not a bad motor for power wise, but you get what you pay for(not much!), an even better motor and not too much more money is theLosi Mach 28.or even the Mach 427(it is a 26) good motors enough power for any truck!!! i prefer the o.s motors, i have one in my 1/8 scale buggy(a 21vg) and one in my t-maxx(a 18tm but getting the new 21 for it!)my other four trucks/cars are electric.
maxximizer is offline   Reply With Quote
Old 12-31-2007, 07:52 PM   #27
Trader Rating: 20 (100%+)
I have the 28 Spec 1S, 32 and the 28RR. The 28 RR has major problems holding a temp. I sent it back in and Axial's joke of a Customer Service told me to iggnore the temps and just run it. They did nothing to rectify the problem, just sent me back the faulty engine. They said its common for the RR to run hot, but it was boiling over and flaming out in under 3 minutes. I sold it on ebay .
The Spec 1S 28 and 32 have been trouble free for 7 gallons on the 28 and 5 gallons on the 32. I couldnt be happier with them. IMHO the 28 Spec 1S will outrun and perform the 32.
I am having a very similar experience with a .28rr in a MGT right now. It is running in the 290 degree range when it runs good, and it's 40 degrees outside! Something isn't right. I'm going to call Axial on Wednesday.
revo_race is offline   Reply With Quote
Old 08-21-2009, 11:44 AM   #28
Default Axial 32 spec 1
HI i am running 3 axial 32 1 in lst 1 in savage 1 in my xray xt8 and every one is awsome tourque all the way makes the xray insane and very easy too tune and repair runs great at 240Deg f loads of power and i have run 5 gallons through it easyest too start motor on the track still and still loads of power. just installed 1 into a savage 4.6 that had the motor blowen got it used 50$ fired but glow ignighter died before i could tune it in but sounds great still
Sinisterministr is offline   Reply With Quote
Old 08-21-2009, 02:09 PM   #29
bigblockt-maxx's Avatar
Send a message via AIM to bigblockt-maxx
dude you dug this thread up from like 2 years ago, you must have been bored or somethinglololol
WICKEDWAYZ RACING
<> LOSI 8ight t 2.0 <> RJ Speed pro stock <> Sportwerks E Turmoil <> HPI Savage <> Ntc3 <>
2010 sponsors - Nitro rcx Racing
bigblockt-maxx is offline   Reply With Quote
Old 11-06-2009, 04:47 PM   #30
xBRxSAIGON's Avatar
The .32RR might be good
XXX-T CR GTB, XXX-NT SPD, LST2 28RR, 8IGHT 1.0 RB WS7
xBRxSAIGON is offline   Reply With Quote
HTML code is On
Forum Jump
axial ax-10 Jammin57 R/C Items: For Sale/Trade 12 09-13-2008 07:48 PM
FS: Axial pull starters for Axial .28 and HPI K4.6 ittjv R/C Items: For Sale/Trade 4 05-31-2007 10:55 AM
Axial 28 loopedout R/C Items: Wanted to Buy 0 04-29-2007 12:21 AM
Axial 28 dabro15 Monster Trucks 6 04-02-2007 07:36 PM
axial vs sts classic xl Monster Trucks 13 07-20-2006 08:45 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
