gear ratios revo,3.3 need some help deciding
I know the revo comes with a 15/38 spur/bell combo and I NEED way more launch from this thing. I have done a few things so far to help lighten the load but I still can't get it to take off like it needs to when coming out of a corner. I need almost buggy like performance if at all possible with the 3.3 trx motor.
I am thinking of going with the RRP 14/40 combo to try and get this thing to rocket out of the corners.
So far I have done a FOC, alum pushrods, close ratio gears, tasis pipe, alum f/r shock mounts.
Future mods are going to be ROTO start for sure, tekno rx box, throttle servo mount, batt box, extended rear a arms, larger fuel tank, center diff/rear brake kit, alum turnbuckles, titanium hinge pins, steel cvd's, single steering servo, alum rocker posts. Only as money permits.
By the time I get that far into It am not sure if the 40/14 combo is going to actually be the best option. I hate to spend the money on something that I am really not going to need to reach my final goals ya know.
Right now I am noticing a slight bit of hesitation on initial take offs and it doesn’t seem to spool up as fast as I would like it to. Don’t get me wrong it is fast, will tear up a stocker, but it still isn’t quick enough on launches.
I guess something else that might need to be answered, is it going to be possible to obtain that buggy take off and spool with a revo
BTW this is the track that I am running on most of the time,
http://www.radiocontrolledchaos.com/...s/track_photos
650 feet long
On site power
On site water for wetting track
AMBrc3 lap timing system
JLap Race Manager
650 feet long
On site power
JLap Race Manager
for that track the 14 40 combo is way to low of a gear
leep the 15/38 and put the close ratio gear transmission
You could try geting a trinity or resinator pipe, and the center diff. would help
and the only way to get buggy like acceleration u would need a big block motor but then u would start have drive train problems.
thats just my opinion
-joe
-joe
