How to prevent roll overs?
#16
Originally Posted by Fred30
Fellas, you have my thanks on this one. I've been searching, reading your posts and have a great baseline to start with.
One question though on the offset wheels. Is this a spacer of some sort to use with my existing wheels or is this a set of offset wheels period? A link would be greatly appreciated.
Thanks,
Thanks,
#17
here are the pro-line adapters. the second a page of some wheels. any of them that are for 23mm HD will work
http://www.amainhobbies.com/product_...oducts_id/2835
http://www.amainhobbies.com/index.ph...sort/2a/page/2
#18
Coolness! Thanks for the links, guys.
Instead of modifying the existing tires, I was going to grab a set of the HPI Dirt Bonz and I know they'll be ok in the dirt obviously, but will they wear prematurely on asphalt? We definitely do a lot of dirt and asphalt driving.
Thanks!
Thanks!
#19
There are a number of ways you c an lower your savage, you can fit limmiters inside your shocks. If you pull tour shocks apart and fit a peice of fuel tubing on the shock shaft and then refit the shaftthis will shorten the length of the shock. Another alternative method is to fit shorter shocks, I run CEN Genisis piggyback shocks, they are shorter than stock, but a lot bigger in diameter. I have about 1'' ground clearance with these shocks. I still have the odd rollover, but that's the nature of trucks. Good luck.
#20
Thanks!
Thanks!
they were on a Savage 25 with a Picco 26.
those were my favorite tires but the truck has Nubz on it now.
