revo fuel tank
revo fuel tank
ok, i have narrowed it down to two tanks. the crt tank and the 8ight T tank. has anyone gone threw tech inspection with a crt tank. i see it used to be labelled as a 145 tank, then i saw that it is actually a 150. if it is really a 145 i am going to get it. i want to stay away from putting stuff in the tank to take up space. i dont like the idea(personal perference). if i have to put something in the tank i guess i can but would rather not. thanks for any help you can give.
the X1-CRT is definitly 145 and its ofna so you know its dependable (imo).
ok, so i just found out that the 8ight t tank has a plastic insert that is screwed into the bottom of the tank. this insert makes it less than 150. i wonder how much less. i am back to where i started. which tank have you guys tried, which is easier to mount? it looks like the crt tank would mount a little easier. thanks in advance.
I have a str tank .I just check rc pro rules 150cc tank is ok on .21 or smaller
