ST-R or MBX5-T
Old 08-27-2006, 03:34 PM
  #31
Its cool man, I come on here to joke around as well.
Get the X5T, gearing or no gearing, everything I have seen or heard says that the truck.
Now go play with your "frikken Lasers"
Muswagon is offline
Old 08-27-2006, 05:10 PM
  #32
LMAO, i will threaten Canada and tell them to pay me one billion dollars or else
yea, i got a month to go over everything, the mugen is at the top of my list for sure. i just hope the Losi 8ight truggy doesnt come out by then, or else i would be going insane on what to choose.
Jesse is offline
Old 08-27-2006, 06:58 PM
  #33
I dont think you have to worry aboot (little canada joke for ya) the Losi Truggy before late winter early spring.
Muswagon is offline
Old 08-27-2006, 07:25 PM
  #34
Z_Schneider's Avatar
The fact that the STR is narrower than the mugen really isnt an issue. Most of the people around here with Jammins are even going to zero offset rims to get narrower, which gives better steering. Also on the issue of rubbing, they shouldnt, and you wont have to worry about it if you just cut the inside rib of the wheel and glue the tire to the one next to the one you cut off. Hope that helps.
Z_Schneider is offline
Old 08-28-2006, 04:19 AM
  #35
KINGZJ's Avatar
Yes the str rims do rub however it is in no way an issue. After a tank or so the tie rod ends get worn a bit and the problem is solved. Just grinding a 45 on the rim takes care of the problem as well.
KINGZJ is offline
Old 09-01-2006, 11:01 AM
  #36
Now that I have had both I would get the Mugen. You wont have to shim the diffs like a pro and it feels more durable for the long mains. The STR is way better in the rough and the tight stuff though. With some narrower wheel adapters I think you could get the Mugen to turn just as well too.
riverrevo is offline
Old 09-13-2006, 10:06 AM
  #37
macnkitty2002's Avatar
definately MBX5T, more bang for less buck, and hex head screws!
macnkitty2002 is offline
Old 09-14-2006, 09:37 AM
  #38
Ok I have 1.5 gallons on the Mugen truck and have only had 1 minor issue(cvd pin backed out a little). After 1.5 gallons on the STR I already spent 50bux on all new diff gears and a broken front arm.
Old 09-20-2006, 05:31 AM
  #39
Who has the MBX5T in stock?
performula is offline
Old 09-20-2006, 05:53 AM
  #40
TonysScrews's Avatar
All of these shops have them in stock.....
Amainhobbies
Carolinas RC
RC Compound - not sure of website but phone number is 865-483-0484
Tony P.
TonysScrews is offline
Old 09-20-2006, 08:58 AM
  #41
Well the Mugen truck seems to be faster for me. I finally got on the podium this year for the first time. The 2 trucks in front of me were both STR's though
Old 09-20-2006, 09:21 AM
  #42
i think it's all going to come down to the best bang for your buck, in which the Mugen is the victor.
Old 09-26-2006, 10:15 PM
  #43
After driving both, if you are on a budget,. i would go with the Mugen MBX5T, if you are not on a budget, i would look into the STR and buy the new BCE extended chassis, i heard the STR is freakin insane with that chassis design.
both notable kits, but it loosk like i will be driving the new mugen for the rest of this year and the whole next year as well. good times!
Jesse is offline
Old 10-18-2006, 05:01 AM
  #44
suntok2's Avatar
Originally Posted by Jesse
i forgot to add, on what tony brought up, i forgot how light the new mugen is, so that does play a roll and its ratio will be different considering. so this is something i think i need to give a try. i think it will be well worth it in the long run.
its awesome to have so many kits to choose from!
Hi Jesse Do you know the GRP truggy tire? Can they fit to dominator Ofna rims?
suntok2 is offline
Old 11-18-2006, 08:12 PM
  #45
I need some help on truggies. I am an electric guy and going to get a truggy but I don't know the difference between the mugen mbx5t or the mbx5t-PROSPEC.
MXer92 is offline
