Sponsored by:
Go Back   R/C Tech Forums > General Forums > Monster Trucks
Old 03-15-2006, 08:45 PM   #1
Default What settings?
I recently got an O.S. .18 CVRX for my Tmaxx. Hopefully I will be breaking it in tomarrow. I just have one question. The manual to the engine says to open the needle valve 2 full turns from the fully closed position for break in. I have heard that this is a very rich setting for O.S. engines. I want to use the heat cycle method to break it in and I know how important it is to get the engine up to operating temperature. I was just wondering if these rich settings will keep it from reaching that temp. For those of you that have broken this engine in using the heat cycle method, did you run at those settings, or did you lean it a little, and if so, how much?
P.S. Is the heat cycle method only good to use if you race? I dont race it, and I'm not a very hard basher. IS it still important to use this method aside from what the manuel says? Thanks for any help.
sho .21 is offline   Reply With Quote
Old 03-16-2006, 12:12 AM   #2
ProudSavageOwnr's Avatar
Send a message via MSN to ProudSavageOwnr Send a message via Yahoo to ProudSavageOwnr
i think u should do wat the manual says....i cant realy say that 2 turns out is rich that sounds like REAL lean to me i know that 4 turns is a pretty normal brake in setting
FG leopard comp w/Trevor Simpson 28.5 bzm crank
HIP Baja 5sct
AE tc5 3.5t speed monster,Futaba 4pks
Raptor G4 ,Raptor e550,Gaui x5,Mini titan v2,Precision aerobatics bandit 4s monster,Carbon z scimitar Jr 11x
ProudSavageOwnr is offline   Reply With Quote
KO EX-10 settings johntrickle1 Radio and Electronics 3 08-16-2008 08:08 PM
li-po settings PLANETSTEREO Electric Off-Road 2 02-27-2006 12:34 AM
P5 settings augerpro Electric Off-Road 8 10-15-2005 09:37 PM
[{(Settings for TA0-4)}] stratuskyo Electric On-Road 242 04-06-2004 02:37 PM
ABS Settings on M8 MadMax Nitro On-Road 1 02-01-2003 09:09 AM
HTML code is On
