i hate my revo
Ill give ya a hundred for it
are you new to nitro? dont do anything stupid yet, are there any problems you are having with it? if so, we can help. but, if you do decide to destroy the defensless revo, than can i get the remaining parts for 120$? lol, jk.
Originally Posted by papadocks
i want to throw my revo at the floor .......by far this is the bigest piece of $h9T.....the thing will never run
Your not asking a question. Your not describing a problem.
Did you break it in? Did you tune it correctly? Did you ask your lhs to help tune it? Or at least get a look over?
ok the truck hasn't been killed yea ,but it's close .........i got about 900 in it and no matter what i do it don't work .........today new head ( yes it's tight !)
engine mods hpi pipe,rpm clutch,rpm bell gear ,and roto start
it willn't run worth a dam .......it guy at the hobby store just likes my money no help
im sorry to hear about the "unhelpfulnees" of your LHS. do you have any others in the area? your turck might simply be tuned wrong. that is usually the main reason for engines running badly or not at all. what exactly is the truck doing? is it boggin badly? dumping alot of smoke out?
truck ran yesterday stalls right before changing gear ........went to the hobby store to have it tuned bought a head and a roto start .......went home and installed all of it ( yes the bearing is in right ) took it back today to have it tuned ......the co&ksuc%er turned the black screw back to std then adjusted it to 5 turns out .....2 minute total 15 dollars later and i'm on my way got home to play won't start
What fuel are you using, and what % nitro ? What aftermarket cooling head did you get ? i had the strangest problem with my 2.5R and nobody could figure it out, finally i went back to stock head, and everything works as a charm ! the aftermarket cooling head was a Nova.
What plugs are you using ?
Did you check the o-ring on the gas tank lid ? if its the blue one, its probably bad, get the new upgraded red/orange o-ring. Also check the fuellines for any cracks or pinholes, also check the back preasure one.
I know what you mean. I have three Revos and nothing but grief with the engines. I thought if it is this hard to tune then I don't went anything to do with the hobby. Then I changed the engine to the OS TM in two of them and OS TZ in the other and I can firmly say I am impressed! These engines run and the only time they quit is went the fuel is out!!!! The TRX2.5 that come stock has very poor construction fitting. The block and sleeve fit is to loose. I suggest an engine change and enjoy.
First thing I would do is make sure your glow plug is good and if you are using a glow stick to start it make sure it is charged up.
just my .02 cents
just my .02 cents
