LST2 Fwd/Rvse problem + other random questions >
Old 02-19-2006, 03:02 PM
  #16
ProudSavageOwnr's Avatar
kool wat was wong with it?
ProudSavageOwnr is offline
Old 02-19-2006, 03:07 PM
  #17
The spring in the servo saver wasn't strong enough to push it into gear when it didn't mesh perfectly first go. So to get it to work 10 out of 10 times I had to have the EPA set so extremely the the servo saver spring was always flexing out of the servo saver (regardless of direction of travel).
So with the stronger spring, it has that extra oomph to push it into gear when I accelerate (and the gears turn to the point that they can mesh).
ImSkitzoAndSoAmI is offline
HTML code is On
