need help building a rock crawler
does any one out there own a rock crawler and can you help me figure out what i need like tires and gearing iv got the axles and a rock crawler chassis but i need to figure out what else i need thanks
Soft tires & low gearing. What kind of axles & chassis do you have? A Clod?
iv got jugg axles and what kinda gearing and tread pattern should i use
HELP PLEASE
people i need help if you got some that would be nice
thanks josh
thanks josh
Suspended
Re: HELP PLEASE
thanks josh
thanks josh
When I rock crawl my Clodbuster I use a very low gear ratio, like an 11 tooth pinion.
You can also try running your tires without foam inserts, this will let the tires deform around rocks and stuff easier.
When rock crawling remember that the slower you go the better your truck will climb over stuff.
You really do not need any special trick stuff just try new things to see what works.
thanks you know any one whos got juggernaut parts they dont want
thanks
thanks
as i am not a pro in this subject, Mr R/c has told you some important points you should do. i also am in the middle of a rock crawler/jumper/basher, its a sstamppede 4x4 with linlk suspension and i am just using maxx tires, motors, and EVx. Since you are building a jugg, (i think) you can get an account to rcmt.net and people always have jugg parts for sale, they also give the best info, people are very nice. check it out.
well i hope this did something,
good luck
nate
good luck
nate
thanks for the info ill go on that web page today and look it up
josh
josh
hey metalmulisha, i dont know if u got my email about when i could meet u at rain city. but i can for sure make it to there on thursday (the 26) and i might go on friday. hope i see u there sometime, and i hope u wanna buy those big bore shocks from me. . mabey u even will want the rustler or a set of tires .
does any one out there have jugg parts or what ever i really want to get this done before april so i can take it out to the desert and try it out there
peace josh email me with info [email protected]
You may have to break down and buy new Jugg parts.
yea i know but i just want to see if people out there have parts they dont want any more
peace
peace
good luck
nate
good luck
nate
