Has anyone done this to their Tmaxx stock tires?
Is it worth the time and effort? Anyone have any input?
http://www.rcnitrotalk.com/forum/showthread.php?t=15139
if the traction in loose dirt and stuff like the guy said is an issue for you then it will probably be worth while for you to try
good luck
steven
My mod
I took a angle grinder in a vice and cut 2 slots in the outer edges of every rib.
the first one 12 mm in from the edge the second 24 mm. Be sure to not grind lower than the surface.this gives real cool traction to stock tmaxx tires. The Poor mans MaxxMasher tire. Takes roughly 10 min a tire and is real easy. you do need a grinder an a 1/4" disk though.
Ps Do it outside
Ps Do it outside
