Tamiya mini cooper
#62
So basically you guys shared one set of tires amongst yourselves, and based on that one night, decided to change the rules? Kind of stinks, some people have allready got spare tires, the kit tires don't wear out THAT quick, the sweeps are not that easy to get, especially for a local shop some might want to support, rather than mail order.... I could see making a choice like this at season's break, but to just do it now after one Thursday night with the locals seems like a short sighted decision in my opinion.... JEFF
#63
#64
Since we run the class weekly up at lsrcc, most of our tires are down to the foams and we need new ones. Since the stock tires are 40.00 and most guys want to keep it cheap we decided to test a set that would be a replacement tire for this class. Since the sweeps are 25.00 and a lot better on our track, better on the motors and last longer we decided to go that route. I really don't care either way and if the guys that travel and race the class have to switch back to the stock tires, "not a problem".
#66
We are looking at 2 options for replacement tires at this time. First option is the Sweep premounts, they are easy to get, cost $10.00 less for a set of 4 and are supposed to last a LONG time. I have s set on order for testing and if they hook up well on carpet they will probably be the replacement for the kit tires. If they don't work at least as well as the stock tires we will go with the Tamiya Spec premounts as the replacement tires. We should be able to make a decision after this Thursdays or next Thursdays points race.
#67
Greg, I believe I voiced all these kind of concerns in person when you were talking of checking these tires out, I knew you were gonna try them, I just didn't think you guys would make sucha quick and IMO rash desicion to change tires midstream, I know Bill's tires lasted a LONG time for how much he ran his car, If he would have rotated front to back once in a while they would last even longer...
So is this only going to be for Thursday night tires for up there the rest of the season, or are they now the tire for all LSRCC races, what about World of Wheels? Which hardness or shore tires are the "right" Tire? How do you police which shore is being used?
#68
So based on one night of racing (100 - 150 laps) you decieded that these new tires will last longer. I think the smart thing would be to have 3 or 4 racers to share these test tires for a month to truely test how long they will last. Or will there be a new test tire next month?
#69
ok so heres my question. every one is saying a new set of mini tires will cost $50. tamiya has a diffrent set of m-chassis tires that are cheaper. and the same size so you wont lose speed do to a smaller tire. plus its still a tamiya tire. and only $6.75 a pair. Homer has been running these all year with very little ware on them and get just as much traction as the stock tires.
http://www.horizonhobby.com/Products...rodID=TAM50568
#70
Wow, where do you want me to start. Where has Homer run these all year? MMR? TCORC? Do these tracks have an open tire rule? Has he been running illegal all year by not running the kit tires at either of these 2 tracks? Why did he switch from the kit tires? Did the kit tires wear out too soon forcing him to buy new tires? Why didn't he get kit tires when he got new ones? How much did it cost to mount these up with inserts and wheels? Are these in stock so others can get them? It says they are on backorder on the link.
If you race at LSRCC a new set of mini tires does not cost $50.00, it's $25.00 for the Sweep premounts and they are legal, that's the point of the rule change.
#71
Wow, where do you want me to start. Where has Homer run these all year? MMR? TCORC? Do these tracks have an open tire rule? Has he been running illegal all year by not running the kit tires at either of these 2 tracks? Why did he switch from the kit tires? How much did it cost to mount these up with inserts and wheels? Are these in stock so others can get them? It says they are on backorder on the link.
#72
Greg
Let me clear some of this up. Brian was telling me he had found a Tamiya tire that was only 6.75 and I said that must be the same tire I bought as my was the cheapest tires I could find. Here is the tires I bought at Hubb.
http://www.horizonhobby.com/Products...rodID=TAM50683
If these are not the correct tires please let me know. The reason that I was changing tires was the tires I had on my 8 year old M03 that has been setting in the closet was dried out. I was lucky enough to be able peel the old tires off the rim and was able to reuse the foam. But at $9.50 a per even with needing to buy rims and foams you are only looking at $30.00 per set.
I am not against changing tires but I think there should have been more testing and more in put by everyone that is racing the Mini.
#73
Homer, I understand completly. It's all about having fun and saving some money too. I was just tying to make a point using Brians post. I am just the messenger here trying to let everyone else know what we are doing at LSRCC. The decision was made based on what the majority of mini racers at our club wanted. Since the begining of the season the question of a replacement tire has come up every time we raced. I found a cheap replacement tire and made sure others were onboard with trying them out with the understanding that if I spent my money to try them out and they worked we would go with the Sweeps so I wouldn't be left hanging with tires I couldn't use myself. Instead of being told that I'm taking the class too damn seriously for trying to make others understand what we are doing and why, it would be nice if I got a little backup from some of the guys that this rule change was made for.
For the record, if it was up to me we would have gone with TCS rules, then we wouldn't have all this B.S. !
#74
3 words
VINTAGE TRANS AM
VINTAGE TRANS AM
