Go Back   R/C Tech Forums > North American Regional Forums > Minnesota and North/South Dakota Racing
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 09-10-2009, 08:49 AM   #16
ABspeed's Avatar
Originally Posted by DriftDreamer06 View Post
the meeting is tonight at MMR direct.
What time?
Associated, LRP, Reedy, Parma
ABspeed is offline   Reply With Quote
Old 09-10-2009, 09:55 AM   #17
I beleive it is 7 pm
dmowery is offline   Reply With Quote
Old 09-10-2009, 11:03 AM   #18
ABspeed's Avatar
I won't be able to be there that late. Maybe I can stop at around 5:30 for a bit and discuss.
Suggestion would be to run a limited late model class. Since that is the biggest class I believe down at Tea's maybe some of those guys would participate.
Also a pan car class. Maybe 17.5 (27t) single cell lipo or 3-cell option? Nascar or Truck bodies.
Old 09-10-2009, 01:01 PM   #19
7 pm meeting time , No on here for early discussion
Old 09-10-2009, 01:18 PM   #20
Send a message via ICQ to Matt D. Send a message via AIM to Matt D. Send a message via MSN to Matt D. Send a message via Yahoo to Matt D.
Limited late model is a blast. Slap a late model body on an off-road buggy, run a spec tire and have fun. Keep in mind this is expected to be a low cost entry level class for people new to (dirt) oval. They aren't the fastest things, don't handle the greatest, but are fun to drive and can be very competitive, they teach the basics of setting up a car for oval.
Here are the rules Tea's was using last year, expect the same for this year.
http://teashobbyshop.com/phpbb/viewt...p?p=5059#p5059
"Racers need to spend more of their efforts on promoting and finding more people to race with, rather than a personal quest to form a class that they can win at."
Matt D. is offline   Reply With Quote
Old 09-10-2009, 03:34 PM   #21
From Teas:
2WD only cars, and you can not take a 4WD car and take out the front drive shafts.
Motor: 19T Locked end bell brushed motor or Brushless 13.5 to roar spec.
Must be a 2WD off road buggy chassis. (Examples: Associated, Team Losi, Duratrax, Traxxas, HPI ect) No chassis modifications, chassis must be original design by the manufacture of that kit. No aftermarket upgrade chassis allowed such as Putnam, JRC, Custom Works, Hugger or simular, X Factory, Factory Works, Dyno Tech, Huricane, basicly no performance enhansing or purpose built kits/conversion allowed. Battery and motor must be in stock location from original manufacture. Modifications to mount body mounts/post or front bumper is allowed.
Must run buggy length shocks and be mounted in stock mounting holes in shock tower and arms. Shock must have full travel, no limiters in shocks.
Must run stock buggy suspension arm mounts and stock buggy arms (if you have to modify the arm mounts or chassis to make mounts work it is not allowed)
No alum outdrives or drive shafts. Steel only
Must run a buggy size rim 2.2" or Custom Works 2" rubber style rim. Rubber tires only, no cap tires or silicone tires allowed, must have visible tread. No foam tires allowed.
Allowed tires: Any rear buggy size off road tire or street pattern type rubber tire or Custom Works Street Trac tire part numbers 6213, 6214 or 6215 on rear only. Any front buggy size off road ribbed or street pattern type rubber tire or Custom Works Street Trac tire part number 6204 or 6205 on front only. All Custom Works rear tires must be mounted on Custom Works rims part number 6253 and all front tires must be mounted on part number 6252. Any other combination must be approved with race director before racing. Tire rules are intended to insure that larger tires are on the rear and narrower tires are on the front. No exceptions, make it work.
Use of different rear hub carrier other then original or modification to original rear hub carrier for clearance on rim is allowed.
Use of wheel spacers is allowed. You must be under the 10" width rule if using spacers.
Motor must be rear mounted behind tires
Must run a slipper clutch assembly, no slipper eliminators allowed, must run a original style gear cover.
Max width with out body is 10", that is outside of tires to outside of tires must clear 10" no exceptions, I don't care what you have to do but make it less then 10"!!!!!!
Weight limit: TBD will be very heavy
We will use DODC (www.dirtoval.com) Late Model body rules
Late Models
The only bodies legal for the Late Model class are those that have been approved by DirtOval.com and are listed on the DirtOval.com Approved Late Model body list. Any manufacturer who would like to have a body approved may contact DirtOval.com for approval specifications and instructions. Molded portion of body can be no longer than 22â€
Paul S is offline   Reply With Quote
Old 09-10-2009, 06:59 PM   #22
ABspeed's Avatar
Wow, now those are some rules! Love it.
Old 09-10-2009, 07:10 PM   #23
MNF1SAND's Avatar
Originally Posted by Paul S View Post
From Teas:
Late Models
There are some REALLY cool cars on that Dirtoval.com site!!!!!!
RACERS: AE 18r Exotek, AE 12r5 Stock, AE TC5 VTA, AE TC5 SS, Serpent 720, FG Comp F1, Slash, FG Off-Road Beetle. COLLECTION: KYOSHO: Javelin, Optima, Tomahawk, Scorpion, Sidewinder, Beetle, Assault, Advance, Integra, Landjump, Vanning, Rowdy Baja. AE: Original RC10 x3, Tekin RC10. TAMIYA: Bruiser x2, Rough Rider,Grasshopper, Cheetah. CUSTOMS: Clodzilla IV, Berzerker, TXT, Rock Rider, Rockbull III, F350. And MORE!
MNF1SAND is offline   Reply With Quote
Old 09-10-2009, 09:36 PM   #24
Good to see everybody tonight. Racing is close! Time to get the cars ready.
Old 09-10-2009, 10:20 PM   #25
Maybe my mind is going but wasn't the meeting originally set for the 12th. Anyway I couldn't make it last night so what was come up with for classes and rules on batterys and motors?
mn_gumby is offline   Reply With Quote
Old 09-10-2009, 10:59 PM   #26
Legend- 17.5 Brushless or 27 Brushed/1c lipo or 3 cell nicd/nimh
House Slash class with 1/8 late model body also Charles.
All the info should be up shortly.
Old 09-11-2009, 03:50 AM   #27
Company Representative
ammdrew's Avatar
Please correct me if I get this wrong. Official classes rules will go up after we go through notes and verify with Roy.
Legends. 3.7v 17.5bl or 27t. (lipo or nimmh). Bushings cars.
MMR slash spec with optional 1/8 late model body
limited late model(current rule package teas is running)
pan car 21.5 bl spec 7.4lipo/ single cell lipo 10.5
I feel like I am missing one but off the top of my head it is not coming to me.
As always on weekend races if we have 2 of a chassis we will run it an see how it developes. With exception no open shock tower classes.
www.molzermoweryracing.com
MMR Direct Minnesotas Premier Indoor Race Facility
North American Importer/Distributor Factory Support for FG, Modelcargo, Serpent, Samba, FF Concepts, RayWood Videos
ammdrew is offline   Reply With Quote
Old 09-11-2009, 07:03 AM   #28
fig865's Avatar
Trader Rating: 16 (100%+)
As an outsider looking in.... I have to say that I'm really pleased to see those class options. I myself have 2 or them ready to race so if I ever get a chance, I'll try to get up there and run with you guys.
fig865 is online now   Reply With Quote
Old 09-11-2009, 08:37 AM   #29
awesome! there's a very strong interest in Legends. should be a blast.
dski is offline   Reply With Quote
Old 09-11-2009, 12:58 PM   #30
Ffejdat's Avatar
Looks like some good rules... One question though, the Slash class, do you HAVE to run the Late Model body mentioned above, or can you run with your Slash truck body on? Thanks!
I got more flavors than Fruit Stripe gum!
Ffejdat is offline   Reply With Quote
Forum Jump
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
