Xxx @ tchr
#46
Dave, 1.yes 2. gotta show it your the boss 3.yes, definitely 4.21
#47
Wow, thanks.
#48
awwwwwww
I am still a ROOKIE!!!!!!!!!!!!!! How many post does it take to become a Sportsman!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
#49
Am I A sportsman yet???
#50
YESSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSS!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!(o kay I wont post anymore now)
#51
good for you, madison!
#52
Hey I tried a new setup last week and it rock, here it is.
Front: springs blue, pistons 60, oil wt 72 1/3, Shocks Completly layed down, 45 deg of caster, camber links short.
Rear: springs asc black, pistons 57 oil wt 10, shocks completly stood up, camber links long, wing pos high, anti squat 10 deg, wheel base long.
Motor, 15x3 speed gems geared at 37/81. (Ride height is arms level front and back)
Notes: The body is painted poop brown the rims are dyed teal and my chassis is sloted out because I saw some fast guy do it.
#54
Yeah, she can get a little "twichy" but I still manage to wheel around the track.
#57
Jeff, I have a setup thats working awsome out there right now, come to the track friday night or Saturday and ill bring ya a setup sheet.
#58
Jeff my setup is also post in the Minnesota thread on Tech Talk
#59
madison, your set-up is specifically for cars that have been tweaked or "put in tha wall" heres a tchr set-up for this page : front: 25wt, 56 pistons, no limiters, silver springs, middle on the tower, inside on the arm, 2 washers under ballstud for camber link, 2-b camber link, 1 washer under spindle ball stud. m3 ribs with full rear foam. rear: 27.5wt, 56 pistons, no limiters, pink springs, 2 on the tower [second to the inside], outside on the arm, 2-b camber link, 2 degrees anti-squat, hubs spaced in the middle, red x-2000 or m3 hole shots with trinity gray foam.
#60
Eric, you forgot to put the bent Tie-rods, hollowed out A-arms and castor blocks. Oh and false peaked battery and a "Tweaked Chassis"
Eric=way fast! Erics car=jacked
