New: Losi Mini 8ight Desert Buggy
#121
You'd think a desert buggy would be able to withstand sand and dust... Got my 12t pinion too, the pinion and gear area was covered in fust and small debris, despite 4 pieces of foam making the carter supposedly better at handling crap.
So far the only good thing I have to say about the DB is tha handling, that thing drives well out of the box.
Anyway, doesn't matter as I plan on transforming it into an on-road basher, but disappointed nonetheless.
Ok so I removed the foam inserts (they came unglued by themselves just like the ESC) and replaced them with highly compressible foam strips for windows and doors and guess what, no more dust under the pinion/ super gear cover.
This thing needs heatsink + fan on the ESC and probably motor for running 3S though, after just a half battery the whole chassis was too hot to handle.
#122
#123
Do you guys have temp guns to give exact readings?
#124
What's getting hot, the esc or motor or both? If the chassis is hot then the motor is causing that.
I agree with noel02, you need to get a temp gun. They aren't expensive and it really helps you to monitor your vehicle.
#125
My LHS had a white one in stock so I picked it up.
[IMG][/IMG]
The only issue I've seen so far is the front tires had a dramatic tow out. There's a turnbuckle wrench in the package.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
#126
It's likely that we're going to have to cut out part of the cockpit area above the motor so it can breathe better.
I like how closed up and tight the body is but it's probably restricting airflow.
I also noticed that my normal esc replacement, Hobbywing 60a, is not going to fit without cutting that cockpit. I may have to find a replacement with a smaller foot print.
It's been raining here everyday so I haven't had a chance to run mine in the dirt yet.
#128
I tried to adjust the toe using the included turnbuckle wrench but the ball cups just pop right off! I love this thing but there are definitely some quality issues.
#130
I put my thumb down on the ball cup as I adjusted the turnbuckles so they wouldn't get too stressed. I believe rpm makes some ball cup replacements if they get too loose on you.
The sun finally came out so here's the first run.
+ YouTube Video | |
#131
New member here and very much enjoying the DB as my reintroction to RC after nearly 20 years. This thing is awesome!
I haven't had any real issues pop up yet, but am considering a couple of upgrades to the electronics, namely the transmitter/receiver and servo. The Spektrum radio while adequate, doesn't feel particularly responsive to throttle or steering input. I've played around the throttle and steering rate but it just doesn't seem to control the car as well as I'd hoped. Some slight adjustments to the toe links improved matters as far as straight line tracking and cornering.
I'm looking at the Hitec or Savox mini servo's and likely a mid range radio system from Futaba or Sanwa like the PRK3a and MX-V. Not gonna be doing any racing, just general bash type of stuff but I'd like to find something bulletproof with good range and zero glitches which I've noticed a few of with the stock setup.
Any thoughts on what would work as far as servos go without having to do any hacking to the chassis would be appreciated. Same for radio systems.
#132
The Hitec 225mg is a direct fit on the M8 buggy. I think this one is the same dimensions. You can try poking the antenna outside of the body to get better range.
#133
#134
Thanks! I'll check that one out.
#135
Thanks.
I took my M8DB on a hike. Here's some footage of it.
+ YouTube Video | |
