Exotek release bigbore mount for mini 8ight
Exotek have introduced new adjustable ‘Big Bore’ motor mount with fan bar for the Losi Mini 8ight-T, Mini 8ight Rally and Mini 8ight. This motor mount is machined from 6061 alloy construction that is polished and anodized factory red. It has longer motor screw slotting in order to allow the installation of larger motors up to 29mm in diameter (works great with the stock motor too). Included also is an alloy fan bar that securely mounts 30mm or 25mm fans (not included).
Exotek site state its 7075
That looks sweet. I love the fan mount too ...
Amain should be getting stock soon
this will be a worthy upgrade!!
I do not understand why?
The stock motor mount is perfect to mount 28mm can motors...till pinion 23T with a little dremel on stock spurs size....
Is the size in diameter of stock motors still coming out with 24mm in 2016?. Go home LOSI! No go if still doing that "nonsense"!!.
A 2840 or 2845 should give nice jumps and still stay in place...not understanding that 24mm 1/24 scale thing !!
Hum...i may had dremelled a little less then 1mm the chassis for the Neu 28mm diameter i had... Well plug & play now!
Also this is RED.... Red is good...should give more 10mph because it's red!
Nice! Like the color
