Mini 8ight or 8ight T?
#31
I'm not sure if you've bought anything yet, but I'm another vote for the truggy. I've had both and the buggywas just a little too small so I ended up selling it pretty quickly. On the truggy I have replaced the motor with a cheap $15 motor and put a $40 quickrun 60a esc in. That's the only thing I've done so far and it's a blast on 2s. I have a couple of the black plastic skateboard kicker ramps that I use for my 1/8 scale monster trucks and it gets tons of air with really nice control too.
#32
I have the buggy, it is great on the street or in VERY short grass. If you want to run in most grass conditions get the truggy. Even my 1/10 scales will end up swimming in long grass.
For the most part, both of them will cog a little. I have a feeling you will end-up replacing the motor and ESC in which ever one you get. Both will have heat issues in the summer on the grass no matter how short it is.
#33
It's such a hard choice!!
I am leaning towards the M8 because it doesn't cog as much as the M8T. Is this true? Which will have a faster speed out of the box? Which will be the best for huge jumps durability wise? Can you just tell me everything you know and which one i should get?
#34
Anyone?
#36
Mini 8ight T.
With a handful of "necessary" upgrades it is quite the little machine!
#38
So what's wrong with the buggy?
How much will in need to spend to make the truggy reliable? I'm shooting for 300$ complete with lipo and charger. So truggy may be a little above but I can stretch it. See my other threads and help me out. Thanks
#40
Here's what I did to my M8T when I purchased it:
ExoTek Carbon Chassis Brace*
ExoTek Carbon Battery Strap*
Steel CVD'S
Hobbywing 35a ESC*
Tactic TTX300 TX/RX combo*
RPM 4-40 Ballcups*
ProLine wheel/tire combo*
Smeared diffs with*automotive*grease
Running the factory motor for now with a 14t pinion on 2s.*
ESC has yet to exceed 100F.*
Motor stays below 150F.
All told I maybe have $400-$450ish in it.
But that's with nearly every potential issue addressed. Truck is SOLID and handles exceptionally well.
I believe the stock Spektrum system is absolute garbage. Mine sure was. Hence the reason I replaced the TX/RX with a Tactic 2.4ghz system. Your experience with Spektrum may differ.
As far as the spur issues people always complain about. I'm still on my factory spur gear. I've had zero issues. I think some people just don't know how to properly set the mesh. Either that or they're overpowered/overgeared.
Steel CVD'S
Hobbywing 35a ESC*
RPM 4-40 Ballcups*
#41
So what are downsides to the buggy?
#42
Clearance. The buggy is great for smooth surfaces only. Not very fun elsewhere. Track days are awesome. Street runs as well.
Do to the ground clearance issues. I converted mine into a Monster Truck. Now it's enjoyable in more terrains than in buggy form.
Here is a picture of my Losi Mini 8ight Monster Truck conversion.
It's a bit more basher friendly this way.
Also I did a Monster Truck conversion for my Mini 8ight-T it's a Blast to run on 3s.
For me the only downside was clearance, but I solved that issue.
The LC Racing lineup is awesome! I have those as well.
You can also get them a NitroRCX.com under the Tacon brand. Truggy isn't available yet. But for your price range this may be the best bet. They are truly amazing and well built.
#43
So I just need to gear down, get a TBR bumper and a lipo? How fast on 2s?
#44
Idk why but I'm still leaning toward the buggy. What upgrades does it need?
#45
Is the m8 with avc more stable than the m8 original? Is the avc in the truggy make it more stable?
