New 1/24 Scale ECX Ruckus and Torment
What are everybody's thoughts on these? They are going to come out in the next two weeks or so. I have a group of friends that are getting these to race in peoples houses and garages. A few Aluminum upgrades have been released so far but I am hoping to find out that the dynamite kit that comes with the Brushless Losi's will fit. Not brushless but a hell of a lot cheaper that the Losi
http://www.ecxrc.com/Search/Default....hTerm=ruck24mt
http://www.ecxrc.com/Search/Default....hTerm=tor24sct
http://www.horizonhobby.com/SearchDi...ce=Q&pageView=
LOSI 1/24
DO PARTS INTERCHANGE WILL LOSI 1/24
JUST RENAMED
JUST RENAMED
The big problem with the ecx's is they don't have proportional steering- at least at 1/36. All right or all left. Ban anyone confirm the 1/24 do? I haven't heard anything different about the new models. I'm not a fan of the Losi Am radios....anyone ever try the hpi 1/32?
The HPI is great, but it has a non-removable battery and takes a while to charge. I would skip it.
https://www.youtube.com/watch?v=K4R1pteUG4I
This was from A-main mod class a couple weeks ago.
https://www.youtube.com/watch?v=F8URx7ZAQ5s
At this scale and track size lap times are in the low 4 second range.
Would you be able to run a 1 cell or 2 cell lipo in these trucks? It would be nice to have some more run time with higher mah batteries.
We have picked up three of them to run on our Basement Homemade Foam track (RCP Style). They run pretty good out of the box but we found them far too fast for a tight track (even though brushed). So we typically dial the TH pot all the way to zero or just above. Unless you like spinouts.
So far the only issues have been the Steering Center Drag link breaking. Losi has an Aluminum replacement but I made one up in 123Design and posted it on Thiniverse, so if you have access to a 3D printer you can simply print them when they break.
One of these days I'll design a better front bumper to protect the weak steering on foam railed tracks and that should solve the issue.
Compared to the Losi version they are much cheaper but I'm wondering if the plastic is also much cheaper (can't justify $229 for a Losi when the Torment is $99... can buy two Torments for the same price). The one thing you do with with the Losi is Oil Filled shocks and yes the Torments are "bouncy". So we might try picking up a shock set and fitting them but you also need to replace the shock towers (or modify them) due to the mounting method. Batteries need a few cycles to get good run-time out of them and throttling back the TH pot helps, we can get up to 18 minutes on a charge. The Losi also has DSM built in so you can use any Spektrum radio that will talk to it (not the ECX). The price of the DSM module is the price of an entire Torment RTR.
For a stock class basement racer these things are a blast, kids are really enjoying them but the Mini-Z's are much faster and more of a joy to modify.
They don't specify that they can handle Lipo so the jury is out on that one.
Cheers
Tim
Cheers
Tim
Great post. I'm excited to get my ruckus this week. I am impressed with the 18 minute run time on the stock battery. That will be fine for our use. I did pick up the Losi micro brushless SCT yesterday and that thing is a beast. I would like to use the Ruckus tires on it though for some added ground clearance and to "truggy" it up a bit. The other added benefit that the Losi models have is the fast charging of the stock lipo. Mine were charged in less than 10 minutes, which is really nice.
Here is a video of my Ruckus on a 2s Lipo battery. This is a great little truck. The steering rack is a weak part that can break quite easily but other than that and a stripped wheel hub it is holding up really well to the power of the lipo.
https://youtu.be/MVZrue4IGgA
