Duratrax Ice Charger Settings NIMH
I know not many racers still using the Duratrax Ice Charger. I know the settings for LiPo batteries. However, going to run a 1/18 SCT and been ages
since I used NIMH batteries. I have picked up a 6 cell 7.2 volt 1600 NIMH battery and need help with settings please Charging Current Discharge Current Peak Sensor Discharge Volt Trickle Current Thanks In Advance |
1.6 amps
the same 6mV cutoff voltage?? .9V no trickle |
comish.. I stoped using a ICE along time ago due to its wild voltages when charging lipo;s and other batterys.. and the charger just recharging a battery over and over
Charge current. do a aa cycle ch/dis.. about 5.. at 1 amp charge n 5 amp discharge to cycle battery Then charge battery .. 1.6 amps dis 5 amps PV 17 mv not high just the ICEs faults require this peak dis .8 volts a cell.. always run a trickle on nimh or nicad.... .25 amps.. |
