My upgraded brushless Losi Mini T
Figured id share my setup with everyone.
Fuze Mini Brushless kit with ESC and motor 4500kv 2s Lipo battery Losi Dual Slipper clutch Losi Smasher Tires HiTec HS-55M servo MIP differential Traxxas 2216 micro receiver (waiting for waterproof case for it) Aluminum rear hubs I had to add a lead weight to the front to keep it from crazy wheelies. Pretty much straight forward installing it all just read instructions. Hardest part was the differential because everything is so small. Need a special work area so you dont lose any ball-bearings. Only thing I had to do that required some cutting was fitting my battery i wanted to move it up as far as i could so just cut some of the chassis plastic that held the original battery in place. Things Id like to add, would be oil filled shocks and more aluminum parts. Shocks are first though I used zip ties for the time to try to stiffen up my spring rate so it doesnt bottom out so easily. http://i27.photobucket.com/albums/c1...ps5xutmkyt.jpg http://i27.photobucket.com/albums/c1...psdd141sie.jpg http://i27.photobucket.com/albums/c1...psbuahi6al.jpg http://i27.photobucket.com/albums/c1...pskmjicm4w.jpg |
Got my waterproof traxxas case installed, perfect fit.
http://i27.photobucket.com/albums/c1...psyjyuehfa.jpg http://i27.photobucket.com/albums/c1...psd96mg3es.jpg |
