Motor Help
Old 12-30-2014, 11:14 PM
Default Motor Help
Where are you guys getting your pinions for your 1/18 brushless motors?
Are you guys using plastic or metal?
Looking for some for my HPI Micro RS4
jeanethics is offline
Old 12-31-2014, 03:45 AM
lemonader83's Avatar
Trader Rating: 16 (100%+)
Look at Robinson racing, that's where you should get all your basic 2mm shaft pinions. Otherwise, the stock option for such a small car should suffice.
lemonader83 is offline
Old 12-31-2014, 04:18 AM
Roelof's Avatar
With 1/8" aluminium tube you have a 2mm -> 3.2mm adapter so you can use 1/10 pinions
Roelof is offline
Old 12-31-2014, 01:03 PM
Ok i am going to check the robinson racing ..
Thank you ordered some stock ones from eBay
