Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Like Tree2Likes
Old 08-23-2017, 11:16 PM   #16
slick2500's Avatar
I must know how you painted that body.
ECX Ruckus 1/10 2wd * Traxxas Stampede XL-5 * Traxxas Summit 1/10 * Team Associated Apex * Team Associated RC10B2 * Arrma Outcast
slick2500 is offline   Reply With Quote
Old 08-24-2017, 05:13 AM   #17
fyrstormer's Avatar
The body in my original post? That was pre-painted by the factory.
Check out Fyrstormer's Garage in the Chat Lounge.
fyrstormer is offline   Reply With Quote
Old 08-24-2017, 02:26 PM   #18
slick2500's Avatar
I can't see the pictures at the moment but the camo one.
Old 08-25-2017, 03:32 PM   #19
fyrstormer's Avatar
Yep, that was factory-painted.
Old 08-28-2017, 10:10 PM   #20
slick2500's Avatar
Dang, I have been trying to find a way to make a digicamo body, the easiest solution I can find is hydrodipping the body, but I am sure that would cost $$$.
Old 08-29-2017, 07:11 AM   #21
fyrstormer's Avatar
You could do it with a silk-screen. Print half of the digital camo pattern in black-and-white using a laser printer, then lay a piece of silk-screen over the top and run it through a heating press. The black pigment on the paper will heat up and melt the plastic that's sealing the silk-screen, producing a mask that you can stick to the inside of the body before painting the first color. Then remove the mask and paint the second color.
T-shirts are usually printed with silk-screens; do you know anyone who makes their own T-shirts?
Old 08-29-2017, 11:58 AM   #22
slick2500's Avatar
I looked into at home hydrodipping, and the film and activator do not cost a hole lot. But there is some secret trick to doing it so it actually comes out right, what that trick is I have not been able to find an answer to as of yet.
Old 08-30-2017, 04:04 AM   #23
fyrstormer's Avatar
Anything useful here? https://www.google.com/search?safe=o...+camo+template
Old 11-14-2017, 12:35 PM   #24
fyrstormer's Avatar
Fixed all the pictures in this thread.
Old 11-15-2017, 08:08 AM   #25
What's the gear pitch you're using? I've been wanting to take a similar platform Apex/RC18, etc. and have everything to do it but the motor using a 48 pitch gear. Can you get 48 pitch spur gears for these?
jmickle11 is offline   Reply With Quote
Old 11-16-2017, 12:40 AM   #26
fyrstormer's Avatar
Hmm. As I recall it uses a 0.5mod spur gear. Associated also sells 0.5mod pinion gears made of sintered steel, which last a lot longer than the nickel-plated-brass pinions sold by Losi.
