Can i charge a venom micro lipo with my losi charger that comes with losi micro lipos
Hi I have a venom micro lipo.The one that comes with the losi micro connector.Can I charge this with the simple losi lipo charger.The one you just plug in and switch on?Thanks for any info.
I have seen a connector with a losi micro one end and a tamyia the other.Would this be ok for charging looks or would it only be for nimhs?
I am not familiar with these products but I can tell you that if the voltage is the same, and the MAH rating for the Venom battery is the same or higher than the Losi battery it will be perfectly safe to charge.
