Atomic RC AMZ MiniZ Brushless 4wd Competitor
#46
It's identical to a Mini-Z AWD ball diff. Just stick that L shaped pin into the hole in the open slot, twist the opposing outdrive till the desired tightness and you're done.
#47
I'm not familiar with Mini Z's but your explanation makes sense. Thanks, now I can adjust the diff!
#48
which mini z bodies fit?
I bought a nissan skyline thinking it would fit but don't think the wheelbase is quite right.
Can someone tell me which mini z bodies fit and if I need any form of mounting hardware?
#49
You want to look for 98mm bodies.
#50
Atomic recently released a 90mm conversion which should be great for the shorter wheelbase rally car bodies. Between those, you should have most bases covered.
Don't buy the W chassis ones (I got an enzo)- and although the wheelbase is fine, the rear width is too narrow on the amz chassis, even using the widest offsets.
I found this guide very helpful - http://mini-z-guide.com/bodies.htm
#51
I purchased one this weekend with a radio version. It is on its way to my home right now from Italy. I also ordered the AMZ lexan touring car body for 98mm. Is it out of the box 98mm or smaller/larger? Also ordered the battery and the bumper for lexan bodies at EGR-mart.
#52
Anybody know if the Kopropo EX-1 or the new EX2 are compatible with the Hobbywing unit (receiver/esc) or do I have to go for the gogolap unit with seperate esc?
#54
Mikedw, which servo do you use in your car?
I broke the stock digital servo so ordered this one- http://hobbyking.com/hobbyking/store...5kg_0_06s.html
I haven't received it yet to know how well it works.
#55
I'm trying this one now:
http://hobbyking.com/hobbyking/store...sec_60deg.html
It's small so I can get the rx on top of it. I had to make sure the wheels were tucked inside the body, without a servo saver I stripped the gears rubbing the wall. I have ~20 batteries on the second one and I'm happy with it.
#56
Which body are you guys using? Lexan Atomic of Autoscale bodies?
#58
I ordered the Atomic LTC body cause I like touringcars. Now I am curious how to paint headlights and taillights since they are not included in the package.
#59
So the EX-1 FHSS is not compatible with the Gogolap rx? I want to use the EX-1 also for my RC powerboats so purchasing the ASF version is no option for me.
