The Losi Mini 80808 Project
#46
#47
Its pretty old and batts have gotten better since they were released, higher c batts are needed for the extreme systems pushing limits.
Its a bigger issue when pushing BB systems in a MERV small batts and high demand dont mesh well lol
#48
and then to top it off, the battery has to be tiny to fit in there. So like I said, ill probably just have to buy the Losi 3s.
#49
I can pick up a Zippy 1500mah 25c 3s lipo on Ebay for the $20. I think ill try it. What the hell right?
#50
Oh yeah!! For the last 2 months every Friday night we all meet @ my house and run our creations. Nitros, Crawlers, Funny cars etc. My battery of choice has been a Venom 2000 20c 2s lipo. Fully charged id get about 20-30 50 yard passes up my street. Car seemed to go faster with each run. Once the battery was done, id bring the car back inside, check everything out, re charge and back out she went.
No 3s yet. Cant find a small enough battery. Researching that now.
http://thunderpowerrc.com/G8ProForce70C.htm
#51
Thunder Power, TP1800-3SPF70, 1800mAh 3-Cell/3S 11.1V. It is the largest 3s lipo that will fit in the mini 8ight without modding the battery tray. 24mm tall, so the battery strap will not fit. No need for it since the battery touches the bottom of the top brace on the chassis. It isn't going any where. Down sides are that TP batteries use a non-standard balance connector that you have to get an adapter for. Dynamite sells an adapter. After I starting using this battery my spur gear stripped and pre mounted tires came unglued on speed runs.
#52
Capacity: 4000Mah
Cells: 3S
Volts : 11.1V
Continuous discharge rate : 40C
Max discharge rate : 80C
Dimensions : 42 x 138 x 25mm
Weight : 304.5g
Max charging rate : 10C
Apply : for Helicopter Airplane
Whats the difference in car and plane batteries? Im gonna say nothing.
Cells: 3S
Volts : 11.1V
Weight : 304.5g
#53
There is no difference except most car packs are hard cased not soft ....
#54
We'll done, keep us updated plz, I will be doing the 0808 conversion
#55
8200
Getting ready to go all out!!! My 4100 is going in my Mini T Pro and an 8200 is going in the Mini 8
Stayed tuned!
Stayed tuned!
#56
What ever happend to this?
#57
