Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Old 12-24-2012, 01:52 AM   #1
Exclamation Losi Mini 8ight 3s LiPo charging
Hello I just got a mini 8ight and was wondering if I could charge the losi 3s lipo with the stock charger that comes with the buggy?! If not which charger would I need? Please help this is important!!!
Thanks!!!
GregTheExtreme is offline   Reply With Quote
Old 12-24-2012, 03:06 AM   #2
Suspended
Trader Rating: 7 (89%+)
Thanks!!!
DON'T PLUG IT IN!!!!!!!!!!!! You need a lipo charger to charge lipo's. All lipos must be balanced when you charge them. The Duratrax Onyx 230 is a good charger but you need a balancer. http://www.hobbypeople.net/duratrax-...FUdxQgodIXsAQw
phathedrc18t is offline   Reply With Quote
Old 12-25-2012, 10:29 AM   #3
rustlererad3's Avatar
Yeah you won't have a house anymore
I Live to Run and Run to Live...Never Fear, Never Give Up, Never Back Down
WE ARE PENN STATE
rustlererad3 is offline   Reply With Quote
Old 12-27-2012, 11:48 AM   #4
wrongchannel's Avatar
Trader Rating: 22 (100%+)
FIRE!
Also, use a LiPo charging sack. That way your battery burns, not your house!
Drive Fast, Turn Some, Buy Parts ...Repeat Process!
wrongchannel is offline   Reply With Quote
Old 12-27-2012, 12:23 PM   #5
You must get a lipo charger. Hobbyking has great ones for 22 bucks.
Although I have charged lipos with a automobile charger with no problem(don't ever do it unless you know what you are doing.
And I NEVER balance my lipos. In my opinion it is not needed. But I am not advising anyone else to not balance them.
holycaveman is offline   Reply With Quote
Old 12-27-2012, 01:47 PM   #6
Trader Rating: 38 (100%+)
K, I don't like your opinion, I'll keep on balance charging mine thank you.
don't take it too serious, they are toys....
vw addict is offline   Reply With Quote
Old 12-27-2012, 02:31 PM   #7
I wouldn't have it any other way.
Years ago when lipos first came out. There were no balancers. Only chargers.
Lipos need a specific charging voltage. And they have to stop at a specific voltage. As well as a specific amp range.
They also should not be drained completely.
Now days the newer chargers will detect a bad cell and not allow you to charge it. Also they won't allow you to over charge the lipo. Also the charger will not let you charge it at a higher or lower cell count than the battery actually reads.
The cells automatically balance to 4.18 to 4.20 without ever touching a balancer to it. And without even having the balancer lead hooked up to the battery?
Unless of course you have a cell bad. In which case your charger will detect it right away, because a bad cell will only hold peak voltage and not steady voltage.
But again I would never want to change the way anyone currently charges their lipo's. Just some information I have learned though the years from dealing with these.
Old 12-27-2012, 07:10 PM   #8
its true that you can trust the charger i just never have i have always balanced mine to be safe
WE ARE PENN STATE
Old 12-27-2012, 07:17 PM   #9
Then you trust the balancer. LOL
Its all good. Be as safe as you can. Can't go wrong there.
Old 12-27-2012, 07:51 PM   #10
yeah i also use a lipo sack...nothing wrong with being safe, that why they invented body armor
WE ARE PENN STATE
Losi Mini 8ight ESC & Motor Thread Rac3rX Micro and Mini Scales 1229 09-10-2017 06:36 PM
Tags
8ight, charger, lipo, losi, mini
