Micro T Questions
Micro T Questions
New to the micro scene.. Buddy and I picked up to losi micro t's the other day from here. They are stock other than the ball bearings in the wheels.
Just a few random questions..
They did not come with chargers but I have a thunder ac6 with deans on it.. Is there an adadpter out there or just somewhere to buy a few plugs to I can solder up my own?
What motor upgrades would you guys recommend? I see these venom "upgraded" motors on ebay? Are they any better than stock? Any cheap reliable brushless setups out there?
What batteries would you recommend? Any good nimhs worth picking up? or should we just go with Lipos?
Thanks in advance.
Thanks in advance.
Thanks in advance.
Thanks in advance.
http://www.hobbyking.com/hobbyking/s...apter_Set.html
You already have bearings so that is good.. Alum gear box is one most people seem to do as it has ball bears and the stock has bushing. Make sure you shim the diff if you do this mod.
there are a ton of brushless setups out you could use. For cheap brushless motors these are good
http://www.hobbyking.com/hobbyking/s...or_4500kv.html
http://www.hobbyking.com/hobbyking/s...r_11500kv.html
Both are out of stock but a lot of people seem to be using those. They need a motor mount mod to mount but it's pretty easy from what I've seen.
I use the losi ones but I just picked up the turbo ace it's a lot more expensive but seems to be everyone's favorite on Micro T Forum.
for a good/cheap ESC that is tiny these seem to be the most popular.
http://blackstarhobbies.com/index.ph...roducts_id=505
and As for Brushed motors
http://blackstarhobbies.com/index.ph...products_id=70
Is the best.. Make sure you break it in and you are going to get a big speed boost with this and a lipo
Check out MicroTforum for all your micro questions.
