Official Mini-Z buggy thread
#91
Ok, no radio yet, but I've ordered the kyosho Aluminium big bore shocks. I'm looking everywhere for the atomic graphite shock stays, but no vendor has them on stock... and they're not available even at atomic website...
#92
Have you ordered one of these? http://shop.tinyrc.com/product.php?p...cat=533&page=1 If not I highly recommend it. There are some folks that have snapped the front of the chassis after a hard front impact. I didn't want to risk it, so it's the first upgrade I did to mine.
#93
#94
That's really the only must have that I can think of. Well, for me a faster motor, and foam tires were a must lol, but thy're really not must haves for everyone.
#96
hi guys, do you think the new mb010ve chassis is worth it? the 50th anniversary edition with the hopups and xspeed motor for a little less seems to be a better deal. Also any opinions on the big bore shocks? thanks.
#97
I would also recommend installing CVDs and/or aluminum dogbones if you can still find them. One of the first things to blow in my buggy during just normal driving was the plastic dogbone.
Foam tires as mentioned already or at least inner sponges for the stock tires are a worthwhile upgrade too.
#98
I also broke a chassis in the same spot, I got the Atomic reinforcement piece mainly to prevent tie rod pop-out, which it did not help. I switched to the Kyosho under guard (50th anniv. VE has this installed already) along with aluminum tie rods and no longer have any problems.
I take note 👍
#99
I'm looking to get a mini z to practice with. I have room for a small on road track at home and think this would fun to do with some friends. Any advice as to what cars to start out with? I have 1/10 tools and chargers. Any tips or anything I should know before getting into mini-z racing?
#100
well well, I had the occasion to drive my miniZ via the radio of a friend. I was hooked instantaneously, jumping it everywhere on a pizza box made kick. Awesome. Tomorrow I should grab my perfex sender.
In the meantime, I got 8 AAA eneloop pro, which should power the unit, a front carbon shocks stay from a brand I don't remember (and I trashed the bag), a rear carbon shocks stay from atomic (actually it comes with some aluminium covers for the motor - that do not fit on the stock motor, anyways...) and the big bore kyosho shocks.
Regarding the bloody atomic kit, it didn't even come with the necessary post to fix the body and the wing. There must be something I don't get, because that is weird...
The big bore shocks are masterpieces of miniaturization... Absolutely gorgeous... However, movement is not really smooth. I hope that this will improve with break-in.
Finally, I would like to switch to a faster motor. Is the Xspeed better?
#101
I'm not sure about the body mounting with the new shock towers, I still run stock towers. The X speed motor is definitely faster than stock though. I prefer the PN Racing or Atomic motors because they have replaceable brushes.
#102
I'm finally ready to drive! This thing is a blast! I love driving it in the living room...
I have few question. The diffs are very loose. Are they supposed to be filled with oil or regulate somehow?
And often does not go backward... i tried the regulations on the perfex radio but no luck.
Any ideas?
Any ideas?
#103
The ESC has a brake function. After braking, you need to return the trigger to neutral and then push it forward again to activate reverse.
Glad to hear you're enjoying it. Which motor did you end up going with?
#104
I just ordered a xspeed motor. Should arrive in few weeks, together with some spares and hop ups 😀
#105
Strange about reverse, but you'll like the little buggy even more once you replace the stock motor.
