Detta SC steel cvds.......
I'm sure someone's LHS has em. We're out of em right now and GP is my supplier so whenever Tower shows em in stock, I'll have em.
If you're in a bind, you can always get the screw in type. It's what I run. They're cheaper and a lil dab o' blue loctite will keep em solid. If you really want posts and nuts.....like now. Get the screw in types, some extra long 2.6mm screws, chop the tops off, thread em into the CVDs aith red loctite and use the accoring nuts.........dubro 2.5s work if you're using anything other then titanium screws.
