1/24 Scale 4WD with Front Stabilization Kit
Here is a DIY Front stabilization bar mounted on a Micro Rally. A stabilization bar actually keeps all four wheels on the ground specially on independent suspension setup with sharp turns.
I got the bar from a used antenna and a couple of mount plates using Tamiya LED mounts;
A small notch is added on each side of the bumper frame for the stabilization bar;
Here is the bar well secured with three LED mounts;
The LED mounts are secured by three screws and a couple of servo arms;
The bar is simply passed through one of the suspension screw hole ( which was drilled through)
Rear suspension remains as is;
TEST VIDEOS:
Tension tests;
http://www.youtube.com/watch?v=2KrVYp3ieZI
Test outdoors;
http://www.youtube.com/watch?v=c8tZb5hRNBU
TEST VIDEOS:
Tension tests;
Test outdoors;
Here is a stabilization kit actual demo as captured on a camera on an animated gif
And here is the effect if i remove that stabilizer bar;
In the meantime, here are a couple of Drag runs with the modified suspension;
+ YouTube Video | |
+ YouTube Video | |
