Castle sidewinder Micro or Mamba Micro Pro?
Both have exactly the same features, adjustments, and operation, but the Pro has more power handling capability. I would suggest the Pro if you use any motor more powerful than the Castle 20mm 5400Kv. The Sidewinder is small and compact while the Pro is average size for a mini.
Power handling is the same for both. They have identical guts. Pro has heat sink, which could help if heating becomes an issue. Might be a factor in heavier cars like the Recoil or Vendetta...
i run the sidewinder 6800 in my 18r. its great. compared to the micro pro, all ive herd is the temps are a little lower on the esc (mines only got up to 108) due to the heat sink, i have also herd that the micro pro is a little smoother. mind you the sidewinder is smooth. save the extra money and buy the sidewinder.
I dont want to sound like I am arguing, because I dont doubt that the Micro Pro is simply a Sidewinder encased with a fancy heatsink. But, it is important to remember that a major factor in power handling with any electronic device is its ability to dissipate heat faster than it can produce it.
I can't find it anymore, but a Castle rep once posted that the Sidewinder was 25A continuous, and the Pro was 40A cont. Some retailers have the Pro listed at only 30A, which would seem more realistic if indeed it were the same internals.
The short answer: if you are going for as much power as you can bolt in the car you should opt for the Pro, but the Sidewinder will handle most motors without issue.
