Half8 Mini Inferno Slipper Clutch Problem. Please Helps Me !
Guys..please helps me..
As a stated above, i've tighten a lot on the slipper clutch but its still slips.
The car doesnt move anymore.
I'm using an Mamba BL system.
or is there something wrong on the other side ?
your opinion i'm really appreciate it.
It should spin and the front and rear wheels should turn.
If the slipper is spinning (not slipping) and the buggy isnt moving your front and rear diffs are blown.
Maybe the pinion on your Mamba is slipping?
Dear Bermbuster,
Tq for corcern. Really appreciate it.
the pinion on the motor shaft is great. i think the front n rear diff is blown also,
but when i put the car on the stand, the wheels is turn.
when i put it back to the ground, then the car cant move.
is it really the diffs is blown ?
Dear Bermbuster,
what exactly is spinning? The wheels arent but what about driveshafts?
If driveshafts are spinning the diffs are blown if the driveshafts are still the slipper is blown.... The other possibility is your mamba has issues. dissconnect the motor and rev it and try to keep the pinion from moving.
A rag over it so you dont burn your fingers..... If you can stop the motor with no effort something is up w the mamba.
Back in the day I had 4 MI s and the drivetrain wasnt the greatest until I really beefed everything up. I spent a small fortune doing it too.
when it is on the ground and you give it power....
sorry late responds.
yesterday i've check it out and the front n rear diff is blown.
Tq so much bro. You helps me a lot.
