mamba 25 esc speed con, not working properly
I have recently just purchased a mamba 25 esc, I did manage to link the remote to the esc, however now i have a problem with the red light flashing and the yellow and the green light flashing even faster and no response at all. Can anyone please help me as i dont want to pull the rest of my hair out.
To determine your software /firmware settings you should use a Castle Link.
Your LHS should have one and be able to check it for you or you can buy a link for $22.
Assuming tx is the remote, it has writen all over it hy model sport.
I have new batteries in it, and all the setting were at o, i made sure of that.
the problem that i have is that the esc is not going into learn mode.
Flashing all colors = speed control is not receiving a valid signal from the receiver, usually indicates the receiver wire is plugged in backwards into the receiver; possible problem with controller or with throttle channel on receiver.
Thats what the LED code means - usually rcvr is plugged in backwards.
