2nd anual Mini Great lakes Challenge!
2nd annual Mini Great lakes Challenge!
This is copied from Hobby talk;
Hi Guys,
Sorry I've been so slow to get things posted but we had to move up the dates for this race this year and I'm swamped with things right now.
But mark your calendars for this race as I promise it will be one not to be missed this year.
March 6th & 7th, 2010 for the 2nd Annual Mini GLC.
2010 Mini Great Lakes Challenge
Hobby Stop West Raceway - Woodville Mall
3725 Williston Road
Northwood, OH 43619
419-471-1108
[email protected]
Sponsored by: BRP, Team Scream, Ratfactor Racing Products, SK Motion, Robotronics, etc...
Track is 80x36 foot Ozite carpet. Pit space for 44+. Chairs on-site, Electric provided. Hobby Shop on-site. AMBrc scoring w/personal TX needed to race. Classes will be the same as last year with the exception of handout brushless motors(I'll provide details later). We may also add a Novice class for kids 14 and under!
Friday March 5th doors will open for practice at 10am. Roadcourse practice from 10am till 3pm then Oval practice from 4pm to 9pm.
Saturday the doors will open at 9am and the Oval Race will start at 11am. 3 Qualifiers and then the Mains. Awards after the Mains.
Sunday the doors will open at 9am and the Roadcourse race will start at 11am. 3 Qualifiers and then the Mains. Awards after the Mains.
E-mail or call and I'll send you the Flyer to sign up. Early registration is expected. Deadline for signups will be March 1st. After March 1st late signups will cost an additional $10 per class. No signups after March 3rd.
More will be posted soon about the race. If you have questions please e-mail to Pat at [email protected].
Thanks................Pat
Hi Guys,
3725 Williston Road
Northwood, OH 43619
419-471-1108
[email protected]
Okay everyone,
Here is the 2010 Flyer and Posting of the classes we are running at this years race.
Check out the new classes! Novice Mini Late Model and Pan Car Novice for Oval is new this year. Also new is Pan Car Brushless Stock for Oval and also Roadcourse.
Sorry but with the additional classes we will not be running the 1/10 Losi Sliders at this race but hope to have a race for them soon! We appreciate your support at the track this year and want to provide you with only the best racing that we can. Thank You!
We will also only be handing out brushed motors this year. If you are running in a brushless stock class you can run any 4200 brushless micro motor. Stock brushed handout motors will be the Associated Super 370.
Here are the classes!
On-Road Classes
Class 1
Micro Touring Stock (4wd)
CHASSIS: M18, M18pro, MRS4, NRX18 or Similar Micro Touring Cars
WHEELBASE: 150mm Max
WIDTH: 110mm Max
MOTOR: Hand Out Brushed Motor
TIRES: Scale Foam or Rubber Tires
BODY: Open 2 or 4 door 1/18 Touring Car/Sedan Style Bodies, chassis and tires must fit inside the body
ELECTRONICS: Open Electronics
BATTERIES: 5 Cell 2/3a 6.0 Volt Limit
Class 2
Micro Touring Super Stock (4wd)
WIDTH: 110mm Max
MOTOR: Open 4200 Brushless Micro Motor
BODY: Open 2 or 4 Door 1/18 Touring Car/Sedan Style Bodies, chassis and tires must fit inside the body
BATTERIES: 2/3a or Lithium Cells 7.4 Volt Limit
Class 3
Micro Touring Open (4wd)
CHASSIS: M18, MRS4, NRX18 or Similar Micro Touring Cars
WIDTH: 110mm Max
MOTOR: Open Brushed or Brushless Micro Motor No Larger than 380 in size
Class 4
Pan Car Stock (2wd)
CHASSIS: Scalpel, BRP or Similar Direct Drive Cars
WIDTH: 115mm Max
TIRES: Foam Tires only
BODY: Open 1/18 Car Body
BATTERIES: 4 Cell 2/3a 4.8 Volt Limit
Class 5
Pan Car Brushless Stock (2wd)
WIDTH: 115mm Max
Class 6
Pan Car Open (2wd)
CHASSIS: Scalpel, BRP or Similar Direct drive cars
WIDTH: 115mm Max
Class 7
Rally Car Stock (4wd)
CHASSIS: Factory Stock Chassis: Max Length 210mm, Max Width 145mm, Max Wheelbase 160mm
TIRES: Stock 18R tires, rims & inserts (No Foam Tires)
BODY: 1/18 Associated Rally Car Body ONLY with original wings (custom paint okay)
BATTERIES: 6 Cell 2/3a 7.2 Volt Limit
Class 8
Rally Car Open (4wd)
CHASSIS: Open Chassis: Max Length 210mm, Max Width 145mm, Max Wheelbase 165mm
TIRES: Rubber or Foam 18R tires, rims & inserts
BODY: Any 1/18 Rally Car Style Body with original wings
BATTERIES: 2/3a or Lithium Cells 7.4 Volts Limit
Class 9
1/14 Open (Recoil, Duratrax TC & similar)
CHASSIS: Max Length 292mm, Max Width 140mm, Max Wheelbase 187mm
MOTOR: Open Brushed or Brushless Micro Motor (400 sized or smaller)
TIRES: Open 1/14 rubber or foam tires
BODY: Touring car/sedan style 1/14 body
Oval Classes
Class 10
Mini Late Model Oval Novice
CHASSIS: Stock Mini Late Model Type Chassis
WHEELBASE: 205mm Max
WIDTH: 180mm Max
TIRES: Stock Mini Late Model Type Rubber Tires
BODY: Open Mini Late Model and Wedge type bodies only
Class 11
Mini Late Model Oval Open
CHASSIS: Open Mini Late Model Type Chassis
WIDTH: 180mm Max
TIRES: Open Mini Late Model Type Tires (Foam or Rubber)
Class 12
Mini Slider Oval Open
CHASSIS: Open Mini Slider Chassis
WHEELBASE: 188mm Max
WIDTH: 180mm Max
TIRES: Open Mini Slider type tires (foam & rubber) front tires must be narrow
BODY: Open Mini Slider Body with non-modified stock wing only
BATTERIES: 2/3a or Lithium Cells 7.4 Volt Limit (batteries MUST fit under the body)
Class 13
1/18 Truck/Buggy Oval Open (2wd or 4wd)
CHASSIS: Open Chassis- Max Wheelbase 165mm, Max Width 185mm
TIRES: Open 1/18 Foam/Rubber tires (1/10 Touring foam & Hex Adapters okay, No Spike rubber tires allowed)
BODY: Must use a stadium style 1/18 truck body or off road buggy
Class 14
1/18 Pan Car Oval Novice (2wd)
CHASSIS: Scalpel, BRP, or Similar Direct drive cars
WIDTH: 115mm Max
Class 15
1/18 Pan Car Oval Stock (2wd)
WIDTH: 115mm Max
Class 16
1/18 Pan Car Oval Brushless Stock (2wd)
WIDTH: 115mm Max
Class 17
1/18 Pan Car Oval Open (2wd)
WIDTH: 115mm Max
Additional Rules:
1. Assume the following: If the rules don’t say you can do it, you can’t.
2. After all qualifying races cars must be placed in tech and drivers must proceed to their turn marshal positions. Substitute marshals are the driver’s responsibility.
3. NO REVERSE. If you use reverse you will be assessed a 5 second stop & go penalty. After 3 stop & go penalties in one race you will be disqualified from that race and your car will be removed from the track. No refunds will be given.
4. No rough or “team” driving. Anyone who is considered to be team driving or rough driving will be disqualified and no refund will be given.
5. All races will be 5 minutes long.
6. 2/3a and Lithium based cells only.
7. All prototypes and one of a kind items must be approved by the race director before being used in competition.
8. 540 type motors are not allowed in any class.
9. Tires may not extend beyond the wheel wells in the micro touring car classes.
10. All vehicles must be free of protruding screws or other sharp edges that could damage the racing surface or marshals skin.
Questions? Please e-mail to [email protected] or call Pat @ 419-471-1108 10am-8pm
On-Road Classes
Class 1
WIDTH: 110mm Max
Class 2
WIDTH: 110mm Max
Class 3
WIDTH: 110mm Max
Class 4
Pan Car Stock (2wd)
WIDTH: 115mm Max
Class 5
WIDTH: 115mm Max
Class 6
Pan Car Open (2wd)
WIDTH: 115mm Max
Class 7
Class 8
Class 9
Oval Classes
Class 10
WIDTH: 180mm Max
Class 11
WIDTH: 180mm Max
Class 12
WIDTH: 180mm Max
Class 13
Class 14
WIDTH: 115mm Max
Class 15
WIDTH: 115mm Max
Class 16
WIDTH: 115mm Max
Class 17
WIDTH: 115mm Max
Additional Rules:
Ron........just talked to Pat tonight about the "new updated" classes and rules for the MGLC. I think everyone should be pleased with them. Pat should be posting them soon tonight on RC Tech and Hobby talk forms.
Dave
Dave
Just saw it Dave! So I just swapped it out.... Above post and flyer is current (now).
Kris and I for shure. Don't know about anyone else yet.. Did you talk any of the east coast guys into comming?
With less than a week until the race who's coming!
Got mini's! Let's race>>>>>>>>>>>>>>>>>>>>>>>>
Thanks,
Pat Falgout
Track Director
3725 Williston Road
Northwood, OH 43619
419-471-1108
[email protected]
Thanks,
Pat Falgout
Track Director
3725 Williston Road
Northwood, OH 43619
419-471-1108
[email protected]
I'll be there can't wait!!!!
Scooby You Guys coming out
Hey guys/gals scheduling this year has been a bit of a challenge for me! I've been busy trying to complete all my work (pay my mortgage) and hobby work (suck my wallet dry ) in time to make it out to see you guys again this year.
There is a chance I may not be able to make it, but I'm doing my level best to make it happen.
If I don't see you all you can expect my support, as much as I can give, and the support of others I'm affiliated with.
My wife and kids have been hounding me to come out with me to Ohio this time . I told them about all the things we saw when we went out there last year. AND I owe some folks some tee shirts, micro bars and beers and I do my best to keep my promises especially when it comes to beers !!
Pat email me tskyers-at-skyrocketracing.com.
It would be great if you could attend again this year.....we sure had a good time last year and enjoyed all the fun. Scooby's car was real good in OnRoad too! But, I do understand if you can't make it with all you have going on right now.
Dave Berry
Hey guys I had an interview yesterday and there is a possibility that I may have another one tomorrow so I don't think I'm going to be able to make it out this year.
I really expected to make it out but I'll be sure you guys have some give aways from us. There is still a chance that I may be able to leave on Saturday so I'm still planning for that possibility.
I'm all packed up and heading over after work
Come on Tory, you can do it! I'm not heading up till Sat. myself.
I'm all set too....all my buddies are going to Cleveland for the ROAR regional....So I gotta go solo this year..
