Originally Posted by thercpro
lower the truck forget the swabar and get any foam tires and celan them with simply green and that should do the trick
The truck is lowered, but lower the front or rear more? Did you forget about the rubber insterts as well to limit how much weight can be shifted to the front or rear of the truck? What thickness insert on the shock shaft should be used? The swaybars can help or hinder this, its a process of figuring what to use front and rear as far as which thickness to use. Taking them off does not automatically solve the problem. Simple green is not allowed at many tracks. In fact we are required to use paragon.
Which foam tires? Purple/Orange? Orange? White? Etc. Which combination?
Try again.
