Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 10-06-2009, 06:28 PM   #1
Dr. Detroit's Avatar
Default Need help with a DuraTrax Ice Charge & a Lipo Battery
I just bought 2 18th Scale Mini-t and a Baja from Ebay and a DuraTrax Ice charger. I am having trouble charging the lipo's with this charger. I am 70% sure I have it set up right but every time I try to charge a battery, A error message comes up and tells me the volts are to low or wrong cell type. I am use to nitro trucks and these are my first battery powered trucks. I am using 3 cell lipo batteries and on one of them it has 1,400mah on it. Any help would be great!
Dr. Detroit is offline   Reply With Quote
Old 10-06-2009, 07:02 PM   #2
2056dennis's Avatar
Trader Rating: 72 (100%+)
Default ice
if you could show pics of your setup on the ice and all the numbers on your lipos would make it easyer to help you with
CRC Gen X 10 gt / 12r5 , / Xray 09 , xray t2r pro / Losi 10th slider and Losi Mini Late / Tekin RS PRO , RS / Specktrum Dx3r / Express Motorsports u been tagged / Finishline Product / Barney's Racing / Dirtburners thanks Bill
LAZER SPEEDWAY where all else IS just a parking lot / Woodville Mall Raceway
2056dennis is offline   Reply With Quote
Old 10-06-2009, 09:00 PM   #3
Should be set to Lipo, 3 cell, 1400mah, and chg. current 1.4A maximum
all other setting should not matter for charging, if you are getting a message with these settings then you likely have a dead cell or two. get a voltmeter and check each cell voltage from the balance plug
burnineyes is offline   Reply With Quote
Tags
18th scale , charging , help!!!! , lipo
Forum Jump
NiMH veteran, needs a crash course in LiPo OTE_TheMissile Radio and Electronics 43 09-15-2008 05:50 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
