Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 07-27-2009, 05:42 AM   #1
Default Which NEU motor for the Revo
Well, I removed the stock motor and ESC from my Revo and installed my Quark Roadster 65a ESC along with a Neu 1105 motor I had laying around from a previous project that never got off the ground. This motor is very light weight at about 65grams, which is good considering how high they are mounted in these Traxxas vehicles. Speed seems similar to the stocker as well and runtimes are much better. Now I find myself wanting more power and I am considering either the 1107/1Y (6150kv, 600watts and 89grams) OR the 1110/1.5D (5600kv, 800watts and 113grams). Either of these should match up well with my Quark ESC and Hyperion 2-cell 1800VX Lipo packs which are rated at 35C discharge and 60C burst discharge.
Which one would you guys go for?
morati is offline   Reply With Quote
Old 07-27-2009, 03:02 PM   #2
jaejw1's Avatar
Send a message via AIM to jaejw1
have you seen any of the videos showing the neu in action in the mini erevo... http://www.youtube.com/watch?v=e2KF4gpRlIo
http://www.youtube.com/watch?v=ysDDk...eature=related
vendetta videos.. http://www.rcuniverse.com/forum/m_5684344/tm.htm
motor review
http://www.rcuniverse.com/forum/m_5643067/tm.htm
http://www.rctech.net/forum/micro-mini-scales/156814-vendetta-bl-motor-reviews-pros-cons.html
tire review
http://www.rcuniverse.com/forum/m_6000527/tm.htm
jaejw1 is offline   Reply With Quote
Old 07-27-2009, 03:26 PM   #3
Yup and I went with the 1110/1.5D.
Old 07-27-2009, 07:43 PM   #4
shady3031's Avatar
Trader Rating: 16 (100%+)
want to sell the 1105
lmk
Losi 8T 2.0 with a powerhouse modded extech 24 ballooning the tires!!!!!
New house toy 1/16 vxl revo on 4s with one broke front axle shaft and many more to come
Special thanks to my wife and family
shady3031 is offline   Reply With Quote
Old 07-27-2009, 08:07 PM   #5
jaejw1's Avatar
were there any heat issues with the 1105?
what gearing did u use?
could u have gone up a tooth or two on the pinion for lil more topend?
motor review
tire review
Old 07-27-2009, 08:22 PM   #6
Shady3031...Thanks for the offer but I think I will keep it as a backup. It is IMO much smoother than the stocker and the runtimes gotta be close to double as well.
Jae...No heat issues with this motor. After a full pack, it seemed to top out at about 130 degrees F. This is with the stock spur gear and the "speed" pinion that comes with the Revo, which is a 23t. I probably could have gone up a tooth or two on the pinion without too much of an increase in temps but then I'd loose some bottom end grunt. The 1105 peaks at about 400watts, so it'll be interesting to see what she'll do with the 1110 which is rated at 800watts. I'm going to throw a 30t pinion on that one as a starting point.
Old 07-27-2009, 08:25 PM   #7
post #912
16th erevo/slash May14th
the 1105 looks tiny in there!
Old 07-27-2009, 09:38 PM   #8
jaejw1's Avatar
post #912
and you got the same speeds.. from a 7000kv motor as you did with a 3000kv motor..
motor review
tire review
Old 07-28-2009, 04:01 AM   #9
I believe the stock motor is rated at approx. 4000kv whereas my 1105 is an earlier 5200kv. version. Geared down from the stock 28t pinion to a 23t and yes, the speeds are similar. The stock motor IS a little stronger, but the NEU is smoother, gets much better runtimes and is less than half the weight.
Forum Jump
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 18865 11-18-2009 04:00 PM
The new Traxxas ERevo thread mistercrash Monster Trucks 473 10-04-2009 02:17 PM
Associated RC8B -Electric bsmooth Electric Off-Road 45 09-22-2009 07:47 AM
losi 8ight T conversion hound_dogs_01 Electric Off-Road 334 06-10-2009 06:45 PM
best monster truck bashers fun machines heady66 Monster Trucks 34 07-14-2008 07:38 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
