Petition for Tekin to make a Long Can 380 Sensored Motor
#31
#32
I rather see a 380 can, short for most of the mini 1/18 cars and long can for the bigger cars like 1/16 Traxxas and for insane power on the small cars.
I think a motor with 28mm outside diameter are max for the smaller cars.
**johan
**johan
#33
its better to have too much power than not enough....
the vendetta sufered from this until tthe right motors were found...
eventhough I dont have the vehicle,, the research I did with the vendetta can be carried over to the traxxas...
once u increase the kv the less power/torque u will have... and for a motor thats 26.5mm or so there is no telling what u will get
this is why I have said the mongoose is not ideal for the vendetta.. smooth but no power
#34
In my opinion there is no need for a 400 size, a 380 (26mm) can is enough a long can one, app 44-45mm say 4-7kv. You will save some weight wich is nice.
The novak 380 diameter is perfect, now we need some longer more torque can
The stock motor weights in on beefy 135+grams..
#37
Hey Tekin, I need two!
#38
I know this thread has been dead for the past year, but found it interesting and wanted to add a new twist to the request for a long block 380 BL motor.
With the established technology of advanced timing on BL motors, making a 380 motor the same length as a 540 would make for a light weight motor to replace silver can classes.
Consider this:
21.5 540 BL motor is rated 1,800kV at 85w
18.5 380 BL motor is rated 4,400kV at 82w
(both are listings from Novak site)
Assuming a higher torque 380 long block motor designed with an end bell that would allow mounting in a car designed for a 540 resulting in a higher power to weight ratio. Naturally, gearing would have to change to reflect the higher RPM 380. But overall, the weight would be reduced. I fear that in the end, it would just make for another class to dilute the existing classes.
Consider this:
#39
I have to disagree with you on that. I have 3 Vendetta's. The SC,TC, and the ST. I run the mongoose in them with a 1800 2cell lipo and i have plenty of power. My SC is the best running truck right now. that thing is dialed in. right now i'm running 22 laps in a 5 min main. Could run alot more but my driving skill is still improving. I love Novak and won't run anything but mongoose systems. Their great if you know how to gear them. But I to would like to see more choices for 1/18th scale cars. So bring on the sensored motor/ esc from tekin.
#40
Hope you like high CoGs. Cause that motors got it.
#42
you mean CoGs - Center of gravity?
if so, then it's not that bad as you may assume
