Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 06-23-2009, 07:01 PM   #1
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Default iwaver class ... any opinions ?
Hi guys,
Local hobby shop its seting up a 1/28 race class, basically for MiniZ and iWavers.
They will import officially the iwavers 02m and the idea its to race STOCK PN70 motor and just allow minor upgrades as shocks and rear diff
Any opinion/experience ?, the main idea its a low budget lot of fun yet competitive class for wednesday nights
thanks,
Pat
Tabushi is offline   Reply With Quote
Old 06-25-2009, 08:26 PM   #2
The program sounds great but the cars don't. You can get MR-02's 27Mhz RTR for about $120.00. The problem with using the I-waver is the electronics. I had a kid just buy one brand new and all the thing would do is cut out in the race. Checked all connections and went through the car thoroughly could not get it to work right. Anyway good luck with the program.
P.S. where are you located?
Bruce Glick,
BGRC monthly
Dunchadoit is offline   Reply With Quote
Old 06-26-2009, 04:48 AM   #3
Bermbuster's Avatar
Originally Posted by Tabushi View Post
Hi guys,
thanks,
Pat
Hey Pat,
I raced w a club in Decatur, IL Flipside Racing and they use Iwavers.
They are cheaper and have some issues but they are repairable and once you get them running they are OK. The quality control on the electronics is lacking. You may have to repair sub standard solder joints and steering pots that are bound. Sometimes you get a dead TX. Again if you have good electronic/mechanical skills you can work through the issues and have fun.
Just remember down the road if you decide to host a big race the iwaver chassis has been in the past illegal to use. (check current Atomic & PN rules)
Good luckwith whatever you choose....personally i run Kyosho.
Bermbuster is offline   Reply With Quote
Old 09-08-2009, 05:47 AM   #4
Wile E Coyote's Avatar
just "showing off" my modified Iwaver 01:
Lithium Ion batteries 7.2v 600mAh, Tamiya TEU104BK ESC with DIY 6v power regulator, Plasma Dash Motor, Towerpro 9gm Micro Servo, T8 pinion gear - top speed run 51 to 53 kph
+ YouTube Video
Wile E Coyote is offline   Reply With Quote
Forum Jump
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
