Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 06-20-2009, 04:10 PM   #1
Cool 3 racing shock kits!
Where can I order some 3 racing shock kits? I couldn't find and the model number or part number for the 18R...
I hear they are better to use casue they are shorter...? I need to set my ride height at 4mm to 4.5 mm
Thanks....
Jeremy
jdogger1 is offline   Reply With Quote
Old 06-20-2009, 04:42 PM   #2
CCH1978's Avatar
Trader Rating: 16 (100%+)
Thanks....
Jeremy
http://thetoyz.com/cart/thetoyz_deta...8705&cat_name=
TRACKMASTERS R/C-TEAM DRIVER
RC18R TAMIYA TA-05 ASSOCIATED TC5 TRAXXAS 1/6th Mini SLASH Traxxas 1/16th Mini Revo
BLADE MSR DURATRAX VENDETTA
THE BEATINGS WILL CONTINUE UNTIL THE MORALE IMPROVES!!!
CCH1978 is offline   Reply With Quote
Old 06-20-2009, 10:28 PM   #3
Psycho Man's Avatar
I don't know if they are any shorter, but they will by far be an improvement over the stock shocks. I have been running them with my 18T since they first came out and they are butter smooth. You will not be disappointed. If you need them to be shorter, just use limiters inside of your shock body. Just be careful as you do want some up travel. If you are not currently running the Exotek chassis for your 18R, I also highly recommend that as well.
Psycho Man
Team Psycho Cells - Team Exotek - D&K Air Designs
Psycho Man is offline   Reply With Quote
Old 06-21-2009, 07:58 AM   #4
These shocks are great and cheap enough to just purchase a new set when needed.They come prebuilt with oil and really soft black springs,good if you want to race with your stock rubber on low grip surface.I'm running 30wt in mine with stock ae blues with the stock spring retainers cause the blue springs will create a higher ride height than you want with the taller spring retainers that the 3racing ones come with.Also,i had to use 18t shock shafts with mine with a small spacer on the inside to equal out droop.The shafts that came with the 3racing 18r shocks made the rear of my 18r sit to low.
airwoods is offline   Reply With Quote
Old 06-21-2009, 01:44 PM   #5
3racing shocks ROCK they are the best bang for buck mod IMO
spawn_x is offline   Reply With Quote
Forum Jump
Townsville Racing - TMORC Forum Sam Contarino Australian Racing 11906 11-02-2009 09:08 PM
Team Associated TC4 Kenshin Electric On-Road 9602 10-29-2009 07:37 AM
The Big Locked Thread donitaROSE Manila Racers 36432 10-11-2009 10:18 PM
confusing choices. redza Nitro Off-Road 46 01-17-2009 08:11 PM
Xray FK05 "RC AMERICA INDOOR/OUTDOOR KIT" Doug D R/C Items: For Sale/Trade 17 11-11-2005 07:36 PM
Summer Cleanout Ver. 1.02 ovalnator R/C Items: For Sale/Trade 14 07-24-2004 04:56 PM
Hpi Rs4 3 For Sale r/c paradise Nitro On-Road 7 12-15-2002 10:35 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
