Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 06-18-2009, 11:55 AM   #1
clamber's Avatar
Default Proper Turnbuckle Removal Technique?
I need to take apart my RC18T, but every time Ive done so in the past Ive broke a turnbuckle. And I really dont want to break a Lunsford so what am I doing wrong? Whats your technique?
clamber is offline   Reply With Quote
Old 06-18-2009, 12:50 PM   #2
one option is to drill a small hole in the cup so you can unscrew the stud
its also about leverage - don't grab the turnbuckle where it has a lot of flex, grab it by where it is closest to the stud and pry it with a flat-head screwdriver
but you are not alone, it is a pain in the rear for me too sometimes. just drill a small hole in the cup
spawn_x is offline   Reply With Quote
Old 06-18-2009, 12:57 PM   #3
Trader Rating: 6 (80%+)
Send a message via AIM to illz302
If your ball cups have a shaft shaped like a hex then you can grab ahold of the ball cup with some pliers right next to the ball and rotate it about 90 degrees and it will pop right off every time.
illz302 is offline   Reply With Quote
Old 06-18-2009, 04:31 PM   #4
Location: Conducting aggressive board meetings at my local track
Trader Rating: 27 (100%+)
There's no effin' way in hell you can break a Lunsford Titanium turnbuckle tryin to remove it from an RC18T
But then again, if anyone we're to prove me wrong on this, it would be you.
Float like an anvil. Sting like a Q-Tip!
SpraydbySprague is offline   Reply With Quote
Old 06-18-2009, 04:33 PM   #5
sLaSh It UPP's Avatar
just freakin take it out there isnt a professional way how to take these out
sLaSh It UPP is offline   Reply With Quote
Old 06-18-2009, 04:56 PM   #6
punkboy's Avatar
I like this suggestion. When you do it this way you minimize the wear of the ball cup that comes from popping it on and off.
Robbie Dodge
RC America☆Xray☆Hudy☆Express Motorsports☆Jaco☆Tekin☆Psycho Cells☆MW Designs☆rDē☆5 Nines Consulting☆Sheckells & Sons Construction
Whopper. Endorsed and Loved by Tony Stewart.
punkboy is offline   Reply With Quote
Old 06-18-2009, 05:07 PM   #7
illhuskerini's Avatar
+1 will have to give this a shot the next time I do some maintenance.
illhuskerini is offline   Reply With Quote
Old 06-18-2009, 07:58 PM   #8
clamber's Avatar
I just realized my Lunsfords already have holes in the cups. Haha.
Old 06-19-2009, 05:36 AM   #9
WOW!!!!
Forum Jump
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
