Go Back   R/C Tech Forums > General Forums > Micro and Mini Scales
Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 06-13-2009, 01:56 PM   #16
clamber's Avatar
Originally Posted by airwoods View Post
Do you have the original radio to hook up to check and see if it helps?
Its the FT kit so no original radio.
clamber is offline   Reply With Quote
Old 06-14-2009, 08:51 PM   #17
geeunit1014's Avatar
Just saw your other thread you have a futaba radio... you definately need to reverse the throttle on futaba radios w/ castle esc's. Read you radio's manual and reverse the throttle, and then re-set the radio to the esc, and you should be good
Mike Gee
Team Driver For: Exotek/Castle/Psycho Cells/GQ Tires/Darkside Designz/Rad Racing
Proud Supporter of: MRL (Micro Racing League) / Final Thoughts RC Club
geeunit1014 is online now   Reply With Quote
Old 06-15-2009, 02:05 PM   #18
clamber's Avatar
Heres a video with my RC18T problem.
When I throttle it, it seems to struggle and it makes a noise like its not working right. Then when I reverse it, it goes smooth and works fine.
The tires seem to be getting full power when forward throttleing it, but its like the power is having a hart time making it move.
Any ideas as to whats causing it.
http://s162.photobucket.com/albums/t...t=MVI_1683.flv
Old 06-18-2009, 11:50 AM   #19
clamber's Avatar
Anyone?
Im beginning to think it may not be the motor because Ive done everything suggested.
It makes a harsh noise when going forward(see the video in my last post). What could I check?
Old 06-18-2009, 06:37 PM   #20
clamber's Avatar
Nobody? Surely you RcTech geniuses could figure out my problem.
Old 06-18-2009, 07:05 PM   #21
Mopar's Avatar
From your video it sounds like your gear mesh is too tight, which would also explain it struggling on accelleration. If you still have problem try your LHS and see if they have someone who can diagnois the issue. I work in a shop and know that some things need to be seen firsthand to figure out.
Mopar is offline   Reply With Quote
Old 06-18-2009, 07:05 PM   #22
I'm sure most of us can diagnose the problem if we had the truck itself.For the grinding noise i would take apart both diffs and inspect proper build and any worn parts in the entire diff front and back and rebuild and shim according to manual,check all bearings for wear,check for any damage to the pinion and spur,bent shaft and for the mamba i would disconnect the pinion and run in both directions and listen for anything abnormal and calibrate it using beep method.Lots of people new to this can get confused calibrating the mamba esc using the beep method.I had two rc18t's,one stock and the other with a 6800 mamba and both were smooth as silk,i still own and race my rc18r in spec.If you dont have a manual you may be able to download thru associated website.These cars a very simple to work on once you've rebuilt it and become familiar with it.
airwoods is offline   Reply With Quote
Old 06-18-2009, 07:18 PM   #23
we will my friend
you might not have something meshed right.. does it roll back and forth by hand smoothly? what size pinion and spur are you using? stock gears - no metal or anything?
trust me, just stick to it, and you will figure all your issues out and have a blast with it
spawn_x is offline   Reply With Quote
Old 06-18-2009, 07:27 PM   #24
clamber's Avatar
Yeah, Ill give them a call tomorrow and see if I can bring it in to look at while Im in town.
I guess Ill tear it apart and try to find the problem.
Originally Posted by spawn_x View Post
we will my friend
Yeah it rolls fine. Im using the smallest pinion that came with the kit I think and yeah all stock gears.
Im going to take it apart soon. Maybe Ill find the problem.
Thanks guys.
Old 06-18-2009, 08:15 PM   #25
there are not a lot of places where there would be a problem, just move stuff around and see what binds
I never had any of the issues you mentioned
Old 06-18-2009, 09:20 PM   #26
clamber's Avatar
I took it apart, and the front diff was kinda tight. I could twist it with my hands, but there was a little resistance compared to the rear diff. So I loosened it up a bit and put it back together and now it does the same thing it did forward but now in reverse. So I guess I have to tighten the front diff a little and then see what it does from there. Ill report back in the morn.
Quick question, could an overtightened diff be causing the lack or acceleration?
Old 06-18-2009, 11:14 PM   #27
How is the ring and pinion gear? are they tight?
I don't think overtightened diff would cause that noise, and if anything it would help acceleration because there would be no slippage and full power to both wheels.
heck maybe its the motor, those wires all the same color doesn't look right to me, but I could be wrong
Old 06-19-2009, 10:12 AM   #28
clamber's Avatar
Ill take the motor off and see. I think the pinion and spur were fairly close together.
Old 06-19-2009, 10:52 AM   #29
For a stock motor tighten the diff till snug but not overly tight,you dont want to risk damage to the diff half with the threads then back out a half turn from snug.With a mod motor back out 1/4 turn from snug,but if you want you can just back out 1/4 turn stock or mod.The soun i hear does sound like to tight of a gear mesh.Take off the spur gear cover underneith the chassis and check very closely to see if there is any play when you move the spur gear and listen closely as you do this,it should be set with very little play.
Old 06-19-2009, 11:09 AM   #30
clamber's Avatar
Wahoo! I partially fixed it!
It now goes decently fast forward. Still a little bit faster/better acceleration in reverse, but its an improvement.
But now my problem of it steering left when accelerating is coming back.
Im going to charge the battery, and take it outside and see how much I fixed it.
Forum Jump
Novak Mongoose frogger Micro and Mini Scales 514 09-28-2009 10:03 PM
Race Director/Track Owner info Wanted chicagokenji Electric On-Road 22 08-21-2009 02:48 PM
Brushless RC18T Problems.....Need some HELP!! smarking1212 Micro and Mini Scales 15 02-24-2009 03:50 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
